[postgis-users] Qgis/Postgis : impossible to open a project
Morten Sickel
morten at sickel.net
Fri Nov 22 04:21:45 PST 2013
Can you manage to find any error messages from postgres? They usually
clear things up. The file looks fine for me. Are you 100% sure you saved
it as a clean text file (utf-files sometimes has a so called byte order
mark at the start, I would not be surprised if that manages to confuse
postgres)
Morten
laurent skrev:
> Dear Nicolas,
> You 're right. The pg_hba.conf file is in the
> C:\ProgramFiles\PostgreSQL\9.1\data folder.
> I tried to modify it to :
> # IPv4 local connections:
> host all all 192.167.40.0/24 trust
> host all all 192.167.40.92 trust
> # IPv6 local connections:
> host all all ::1/128 trust
> I saved the file. Unfortunatly my postgres serve does not work no longer.
> The postgres service can't restart...
> Could you throw light for me?
> Thanks.
> http://postgis.17.x6.nabble.com/Qgis-Postgis-impossible-to-open-a-project-tp5003712p5004939.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
