[postgis-users] Postgis overlapping two linestrings
Ani Alamo alamo.ani at gmail.com
Fri Nov 22 08:17:01 PST 2013
Hi!
I need a specific function to get if two linestring overlaps. e.g.
Linestring 1 is Point (0, 0) : Point (10, 0) Linestring 2 is Point (0, 0) :
Point (3, 0)
In this case I need "true" result because LineString 1 overlaps in
different points like 0,0 1,0 2,0 & 3,0. I dont need the common points, I
only need if two linestring overlaps or not. I tried with this function in
postgis...
overlaps(buffer(LINESTRING1, 0.001), buffer(LINESTRING2, 0.001))
I create a buffer on both linestrings... but muy problem is some times
works better, some times not.
Can you help me please?
Thanks!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131122/6e44aecd/attachment.html>
