[postgis-users] Postgis overlapping two linestrings
Rémi Cura
remi.cura at gmail.com
Fri Nov 22 09:27:05 PST 2013
You may try
http://postgis.net/docs/ST_SharedPaths.html
Cheers,
Rémi-C
2013/11/22 Ani Alamo <alamo.ani at gmail.com>
> I tried this function:
> intersects(buffer(LINESTRING1, 0.001), buffer(LINESTRING2, 0.001))
> Always gives me "false" result.
> I don't know what to do!
>> Uhm... exactly I have this linestrings:
>> LINESTRING(2.118932325 41.398745991,2.168720219 41.385631938)
>> LINESTRING(2.142346041 41.398526436,2.111181541 41.409216161)
>> intersections gives me:
>> GeometryCollection: GEOMETRYCOLLECTION EMPTY
>> intersects gives me:
>> false
>> but when I see the line drawn on map I see both lines intersect in a
>> little "section" (strectch). But really when I use intersects or
>> intersection functions gives me "unavailable intersection"... and when I
>> use OVERLAPS function
>> overlaps(buffer(LINESTRING1, 0.001), buffer(LINESTRING2, 0.001)) also
>> gives me "false".
>> Another ideas please??
>> 2013/11/22 James David Smith <james.david.smith at gmail.com>
>>> Hi Ani,
>>> Have you looked into st_intersects() ? and st_intersection() ?
>>> http://postgis.refractions.net/docs/ST_Intersects.html
>>> James
>>> On 22 November 2013 16:17, Ani Alamo <alamo.ani at gmail.com> wrote:
>>> > Hi!
>>> > I need a specific function to get if two linestring overlaps. e.g.
>>> > Linestring 1 is Point (0, 0) : Point (10, 0) Linestring 2 is Point (0,
>>> 0) :
>>> > Point (3, 0)
>>> > In this case I need "true" result because LineString 1 overlaps in
>>> different
>>> > points like 0,0 1,0 2,0 & 3,0. I dont need the common points, I only
>>> need if
>>> > two linestring overlaps or not. I tried with this function in
>>> postgis...
>>> > I create a buffer on both linestrings... but muy problem is some times
>>> works
>>> > better, some times not.
>>> > Can you help me please?
>>> > Thanks!
>>> > _______________________________________________
>>> > postgis-users mailing list
>>> > postgis-users at lists.osgeo.org
>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131122/1d2174e6/attachment.html>
