[postgis-users] Postgis raster : jfif? jp2?
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Nov 25 06:55:50 PST 2013
Laurent,
The list of available drivers is dependent on your installation. Normally if you can gdalinfo a raster, raster2psgql should be able to load it. So the first thing is: Does gdalinfo works fine? If not then you should refer to the gdal list. I yes then it might be a raster2pgsql problem which would be surprising.
Pierre
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of laurent
> Sent: Monday, November 25, 2013 9:23 AM
> To: postgis-users at lists.osgeo.org
> Subject: [postgis-users] Postgis raster : jfif? jp2?
> Dear all,
> I would like import a world raster DEM in my postgis db. I would like use
> raster2pgsql.
> When i try to convert the jp2 file or jfif file to the .sql, i have an error
> message saying "Unable to read raster".
> When i type: raster2pgsql -G , the jpeg jfif seems to be in the list. Why i
> have this error message? Except tiff, what raster format can be imported
> into postgis db?
> View this message in context: http://postgis.17.x6.nabble.com/Postgis-
> raster-jfif-jp2-tp5004960.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
