[postgis-users] Simple Line Density
Karl Zinglersen karl.zinglersen at gmail.com
Thu Nov 28 05:37:20 PST 2013
A very good idea, I've forgot it in this installation. Thanks
Karl
Den onsdag den 27. november 2013 13.49.08 UTC-3 skrev Rémi Cura:
> Maybe you should tweak your postgres conf file ,
> default conf is very savy
> http://www.postgresql.org/docs/9.3/static/runtime-config.html
> Cheers,
> Rémi-C
> 2013/11/27 Karl Zinglersen <karl.zi... at gmail.com <javascript:>>
>> Hi,
>> I am dealing with the same types of data and issues as Jeff.
>> My procedure for data clean up is:
>> 1) CSV files into PostGIS as points
>> 1.1) ST_TRANSFORM to projected spatial reference (here EPSG:32621 / UTM
>> zone 21 N WGS84)
>> 2) ST_MAKELINE to "sub"-lines via PARTITION BY
>> 3) Create a gridded polygon layer in same srid
>> 4) Run equivalent to select cell_id, line_id from cells, lines where
>> intersects(lines.geom, cells.geom
>> - but my postgis runs out of memory after a while. And I am sorry to say
>> Spatial Analyst doesn't.
>> Is there more memory cheap way to do it in PostGIS (e.g. via the raster
>> functions - although I haven't found i yet).
>> Karl
>> Den onsdag den 26. december 2012 09.58.43 UTC-3 skrev Jeff Adams - NOAA
>> Affiliate:
>>> Hi Brent,
>>> Thanks for the response. I don't think your original response made it
>>> into my inbox via the list, but now I see it on the website thread. That
>>> seems like it might be a viable alternative, I just worry about those
>>> vessel tracks that would be clearly outside of a particular grid cell, but
>>> whose buffer would bleed over. How did you handle this type of situation?
>>> Jeff
>>> On Mon, Dec 24, 2012 at 7:22 PM, <pcr... at pcreso.com> wrote:
>>>> Jeff,
>>>> Did you see my reply using vessel tracklines as vectors & a grid in
>>>> Postgis to do exactly what you describe?
>>>> Given we were looking at benthic impact, we buffered the tracklines to
>>>> create polygons representing the swept area of the deployed fishing gear.
>>>> These were clipped by the cells, & we could generate statistics suca as the
>>>> cumulative swept area of all tracks with each cell, number of times each
>>>> cell was crossed, & given the tracklines have a timestamp associated with
>>>> them, we could also look at the temporal pattern of tracks crossing cells,
>>>> for things like seasonal impacts & variation between seasons.
>>>> Cheers,
>>>>   Brent Wood
>> postgis-users mailing list
>> postgi... at lists.osgeo.org <javascript:>
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131128/05b5a1a4/attachment-0001.html>
