[postgis-users] Simple Line Density
Karl Zinglersen
karl.zinglersen at gmail.com
Thu Nov 28 05:38:08 PST 2013
Hi Pierre,
Thanks for the link to the add-on and the sql statements.
Karl
Den onsdag den 27. november 2013 14.21.46 UTC-3 skrev Pierre Racine:
> Hi Karl,
> I do this with the ST_ExtractToRaster() function from the PostGIS Add-ons:
> https://github.com/pedrogit/postgisaddons/releases/tag/1.21
> I just added a SUM_OF_LENGTHS method to ST_ExtractToRaster().
> Look at the ST_ExtractToRaster() function in the postgis_addons.sql file
> for an example. In your case it should look like this:
> SELECT ST_ExtractToRaster(ST_AddBand(ST_MakeEmptyRaster(rast), '32BF'),
> 'public', 'geomtable', 'geom', null, 'SUM_OF_LENGTHS') rast
> FROM refrastertable;
> You should have a reference raster already existing in a table and your
> lines should be indexed.
> Pierre
> > -----Original Message-----
> > From: postgis-us... at lists.osgeo.org <javascript:> [mailto:postgis-users-<javascript:>
> > bou... at lists.osgeo.org <javascript:>] On Behalf Of Karl Zinglersen
> > Sent: Wednesday, November 27, 2013 11:30 AM
> > To: postgi... at googlegroups.com <javascript:>
> > Cc: PostGIS Users Discussion
> > Subject: Re: [postgis-users] Simple Line Density
> > Hi,
> > I am dealing with the same types of data and issues as Jeff.
> > My procedure for data clean up is:
> > 1) CSV files into PostGIS as points
> > 1.1) ST_TRANSFORM to projected spatial reference (here EPSG:32621 /
> > UTM zone 21 N WGS84)
> > 2) ST_MAKELINE to "sub"-lines via PARTITION BY
> > 3) Create a gridded polygon layer in same srid
> > 4) Run equivalent to select cell_id, line_id from cells, lines where
> > intersects(lines.geom, cells.geom
> > - but my postgis runs out of memory after a while. And I am sorry to say
> > Spatial Analyst doesn't.
> > Is there more memory cheap way to do it in PostGIS (e.g. via the raster
> > functions - although I haven't found i yet).
> > Karl
> > Den onsdag den 26. december 2012 09.58.43 UTC-3 skrev Jeff Adams -
> > NOAA Affiliate:
> > Hi Brent,
> > Thanks for the response. I don't think your original response
> made
> > it into my inbox via the list, but now I see it on the website thread.
> That
> > seems like it might be a viable alternative, I just worry about those
> vessel
> > tracks that would be clearly outside of a particular grid cell, but
> whose
> > buffer would bleed over. How did you handle this type of situation?
> > Jeff
> > On Mon, Dec 24, 2012 at 7:22 PM, <pcr... at pcreso.com
> > <javascript:> > wrote:
> > Jeff,
> > Did you see my reply using vessel tracklines as vectors & a grid in
> Postgis to
> > do exactly what you describe?
> > Given we were looking at benthic impact, we buffered the tracklines to
> > create polygons representing the swept area of the deployed fishing
> gear.
> > These were clipped by the cells, & we could generate statistics suca as
> the
> > cumulative swept area of all tracks with each cell, number of times each
> cell
> > was crossed, & given the tracklines have a timestamp associated with
> them,
> > we could also look at the temporal pattern of tracks crossing cells, for
> > things like seasonal impacts & variation between seasons.
> > Cheers,
> > Brent Wood
> postgis-users mailing list
> postgi... at lists.osgeo.org <javascript:>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131128/79e2a364/attachment-0001.html>
