[postgis-users] Grid of points inside Polygon
James David Smith
james.david.smith at gmail.com
Fri Nov 29 01:53:29 PST 2013
Hi Remi / all,
I am just coming back to this project. I have made some progress. But
would appreciate advice on how best to proceed now. What I have now is
a table with two columns, 'st_x' and 'st_y'. They are the 20 metre by
20 metre grid points that are within 1km of main roads in the UK. The
table has 499,677,666 rows! Because of the method that I used to
create this however, I have alot of duplication of points. So I think
I need to do something like:
CREATE TABLE grid_no_duplications AS (SELECT DISTINCT(x, y) FROM grid);
However I thought that first I could put an index on it?
CREATE INDEX grid_x_y ON grid (st_x, st_y);
Is this a good approach?
Cheers
James
On 15 November 2013 16:39, Rémi Cura <remi.cura at gmail.com> wrote:
> good =)
> It is better to do the buffer computation first,
> because this way you are sure youwon't compute the same buffer many times.
> Something like (not so sure without trying it)
> UPDATE ukmajrdbuffer SET geom = ST_Buffer(geom,1000);
> You may have an error if you hav e a fixed geom data type, then you could
> just add a new column like
> ALTER TABLE ukmajrdbuffer ADD COLUMN the_geom geometry ;
> UPDATE ukmajrdbuffer SET the_geom = ST_Buffer(geom,1000);
> Cheers,
> Rémi-C
> 2013/11/15 James David Smith <james.david.smith at gmail.com>
>> Hey Remi,
>> I've actually managed to get the file 'ukmajorroads' already and have
>> loaded it into my database. There are 395356 rows in the database. There is
>> a field called 'geom' and I have built an index on it as below;
>> CREATE INDEX ukrds_index ON ukrds USING GIST (geom);
>> So should I now run the same query, but do the buffering of the roads 'on
>> the fly' maybe? For example as below?
>> CREATE TABLE lines_for_each_road AS
>> WITH all_lines AS (
>> SELECT *
>> FROM all_lines
>> cutted_lines AS ( --we cut the line to keep only part of lines inside
>> road_buffer
>> SELECT ST_Intersection(all_lines.the_geom,st_buffer(ukmajrdbuffer.geom,
>> 1000)) as lines_cutted, direction
>> FROM ukmajrdbuffer, all_lines
>> WHERE ST_Intersects(st_buffer(ukmajrdbuffer.geom, 1000),
>> all_lines.the_geom)=TRUE
>> cutted_lines_SN AS ( --this is the cutted lines which going from South to
>> North
>> SELECT *
>> FROM cutted_lines
>> WHERE direction = 'SN'
>> cutted_lines_EW AS ( --this is the cutted lines going from East toWest
>> SELECT *
>> FROM cutted_lines
>> WHERE direction = 'EW'
>> points AS ( -- we take the intersection of EW lines with SN lines , that
>> is the points on the grid.
>> SELECT ST_Intersection(clSN.lines_cutted, clEW.lines_cutted) AS point
>> FROM cutted_lines_SN as clSN, cutted_lines_EW AS clEW
>> WHERE ST_Intersects(clSN.lines_cutted, clEW.lines_cutted)=TRUE --no point
>> ot compute an intersection if lines don't intersect
>> SELECT row_number() over() AS id , point
>> FROM points ;
>> On 15 November 2013 15:42, Rémi Cura <remi.cura at gmail.com> wrote:
>>> Still is a shame :
>>> with proper data we should have some result with about one hour i guess.
>>> Cheers,
>>> Rémi C
>>>> Remi,
>>>> Ok. Cool. I've set the below query running. On Monday I will also
>>>> attempt to get the original road lines file too. Let's see if we have
>>>> a result on Monday.
>>>> WITH all_lines AS (
>>>> SELECT *
>>>> FROM all_lines
>>>> road_buffer
>>>> SELECT ST_Intersection(all_lines.the_geom,ukmajrdbuffer.geom) as
>>>> WHERE ST_Intersects(ukmajrdbuffer.geom, all_lines.the_geom)=TRUE
>>>> to North
>>>> SELECT *
>>>> FROM cutted_lines
>>>> SELECT *
>>>> FROM cutted_lines
>>>> that is the points on the grid.
>>>> point ot compute an intersection if lines don't intersect
>>>> FROM points ;
>>>> Thanks
>>>> James
>>>> On 15 November 2013 15:37, Rémi Cura <remi.cura at gmail.com> wrote:
>>>> > You should try to get the original road file, because i will be very
>>>> > easy to
>>>> > reapply some buffer and filtering to keep only major road.
>>>> > Yet, why not let it run during the week end?
>>>> > Cheers,
>>>> > Rémi-C
>>>> >> Hey Remi,
>>>> >> Do you think before I try running the big query you have just sent
>>>> >> me,
>>>> >> that I should go back and try to get the original file of uk roads? I
>>>> >> mean the very original file that has not had any buffers applied or
>>>> >> any merging done.
>>>> >> Or shall we just go for it and see if it has finished when I come
>>>> >> into
>>>> >> work on Monday?! haha.
>>>> >> Thanks
>>>> >> James
>>>> >> On 15 November 2013 14:01, Rémi Cura <remi.cura at gmail.com> wrote:
>>>> >> > Outch,
>>>> >> > you have only 8 roads in GB? =)
>>>> >> > This is not going to go fast till you don't have some dozens k's of
>>>> >> > roads.
>>>> >> > I'm guessing you are not at will to send those roads?
>>>> >> > The next step will be (when you'll be sure everything is OK)
>>>> >> > WITH all_lines AS (
>>>> >> > SELECT *
>>>> >> > FROM all_lines
>>>> >> > inside
>>>> >> > road_buffer
>>>> >> > South
>>>> >> > to
>>>> >> > North
>>>> >> > SELECT *
>>>> >> > FROM cutted_lines
>>>> >> > toWest
>>>> >> > SELECT *
>>>> >> > FROM cutted_lines
>>>> >> > that is
>>>> >> > point
>>>> >> > point ot
>>>> >> > FROM points ;
>>>> >> > Cheers,
>>>> >> > Rémi-C
>>>> >> >> Hey Remi,
>>>> >> >> I'll do a few checks and get back to you. Maybe I did something
>>>> >> >> wrong
>>>> >> >> because I set this query going on my local PostgreSQL installation
>>>> >> >> but
>>>> >> >> also on our Linux Cluster machine which is much more powerful. And
>>>> >> >> it
>>>> >> >> finished on my local installation BEFORE the cluster. So maybe I
>>>> >> >> did
>>>> >> >> something wrong on the local query.
>>>> >> >> The query that has finished took about 1 hour.
>>>> >> >> The query on our cluster is still running.
>>>> >> >> select count(*) from ukmajrdbuffer = 8
>>>> >> >> This is because before I was given the data the roads buffer had
>>>> >> >> already been dissolved unfortunately.
>>>> >> >> James
>>>> >> >> On 15 November 2013 13:43, Rémi Cura <remi.cura at gmail.com> wrote:
>>>> >> >> > Good !
>>>> >> >> > Something is strange with the result,
>>>> >> >> > you get only 190k lines intersecting road buffer,
>>>> >> >> > it is very few , I expected at least 10times this!
>>>> >> >> > How many time took this computing by the way?
>>>> >> >> > How many road buffer geom do you have ? (select count(*) from
>>>> >> >> > ukmajrdbuffer
>>>> >> >> > Cheers,
>>>> >> >> > Rémi-C
>>>> >> >> >> Hey.
>>>> >> >> >> Yes, it's done. Was just getting some lunch! :-)
>>>> >> >> >> select count(*) from lines_for_each_road
>>>> >> >> >> Result = 187033
>>>> >> >> >> I have also just ran 'VACUUM ANALYZE' on the tables
>>>> >> >> >> 'lines_for_each_road' as well as the table 'all_lines'
>>>> >> >> >> I also can confirm that I have ran the following commands:
>>>> >> >> >> CREATE INDEX all_lines_index ON all_lines USING GIST ( the_geom
>>>> >> >> >> CREATE INDEX ukmajrdbuffer_index ON ukmajrdbuffer USING GIST
>>>> >> >> >> (geom);
>>>> >> >> >> Should we now uncomment this line from the previous query?
>>>> >> >> >> " SELECT row_number() over() AS id--,* "
>>>> >> >> >> Thanks again Remi,
>>>> >> >> >> James
>>>> >> >> >> On 15 November 2013 13:14, Rémi Cura <remi.cura at gmail.com>
>>>> >> >> >> wrote:
>>>> >> >> >> > Also if you do have indexes,
>>>> >> >> >> > can you run a "VACUUM ANALYZE", so that the indexes will be
>>>> >> >> >> > used?
>>>> >> >> >> > Cheers,
>>>> >> >> >> > Rémi-C
>>>> >> >> >> > 2013/11/15 Rémi Cura <remi.cura at gmail.com>
>>>> >> >> >> >> It should be finished by now,
>>>> >> >> >> >> can you check you have geom indexes on :
>>>> >> >> >> >> "ukmajrdbuffer.geom" and "all_lines.the_geom"
>>>> >> >> >> >> How many geoms do you have in "ukmajrdbuffer"?
>>>> >> >> >> >> Cheers,
>>>> >> >> >> >> Rémi-C
>>>> >> >> >> >>> Hey Sandro,
>>>> >> >> >> >>> Thanks for this, it is at least twice faster =)
>>>> >> >> >> >>> Cheers,
>>>> >> >> >> >>> Rémi-C
>>>> >> >> >> >>>> Thanks both. Geometries now fixed.
>>>> >> >> >> >>>> The query 'CREATE TABLE lines_for_each_road....' has now
>>>> >> >> >> >>>> been
>>>> >> >> >> >>>> set
>>>> >> >> >> >>>> running. Will report back when it's done. I suspect it may
>>>> >> >> >> >>>> take
>>>> >> >> >> >>>> a
>>>> >> >> >> >>>> while!
>>>> >> >> >> >>>> James
>>>> >> >> >> >>>> On 15 November 2013 11:03, Sandro Santilli
>>>> >> >> >> >>>> <strk at keybit.net>
>>>> >> >> >> >>>> wrote:
>>>> >> >> >> >>>> > On Fri, Nov 15, 2013 at 11:50:42AM +0100, Rémi Cura
>>>> >> >> >> >>>> > wrote:
>>>> >> >> >> >>>> >> Yep, maybe something like
>>>> >> >> >> >>>> >> ST_MakeValid(the_geom)
>>>> >> >> >> >>>> >> WHERE ST_IsValid(the_geom) = FALSE
>>>> >> >> >> >>>> > ST_MakeValid internally checks for ST_IsValid, so no
>>>> >> >> >> >>>> > need
>>>> >> >> >> >>>> > to add the condition (which would run the test twice).
>>>> >> >> >> >>>> > --strk;
>>>> >> >> >> >>>> > _______________________________________________
>>>> >> >> >> >>>> > postgis-users mailing list
>>>> >> >> >> >>>> > postgis-users at lists.osgeo.org
>>>> >> >> >> >>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
