[postgis-users] Fwd: line direction
George Silva
georger.silva at gmail.com
Fri Oct 4 07:12:00 PDT 2013
The direction is always considered from start point to end point. You need
to use these methods to determine everything else.
Em 04/10/2013 08:43, "franco base" <frenk.calza at gmail.com> escreveu:
> Hi Stephen
> How can you explain that the st_offsetcurve make offset according to line
> direction.
> For example
> SELECT ST_OffsetCurve (geom, -20) as geom_off
> FROM table
> WHERE id_arc in (1690,1693)
> give me the result that you can see in the attached image rendering in qgis
> (One Direction on the left, the other on the right).
> So I have the dirction information inside the arc geometry.
> Thanks
> fb
> 2013/5/16 Stephen Woodbridge <woodbri at swoodbridge.com>
>> How do you define arc direction?
>> If you had a function:
>> select getArcDirection(arc);
>> What would you expect the output to be?
>> In your image, the arc direction is a function of the labeling algorithm
>> in combination with this that of the arc. For example if the label were
>> flipped upside down and written along the underside of the line then the
>> arc direction symbol would have to be reversed. So we can see that it is a
>> function of the label and not just the arc alone.
>> postgis does not do rendering so it can not define that.
>> -Steve
>> On 5/16/2013 11:14 AM, franco base wrote:
>>> I send again message because it was blocked for the attcahed file too big
>>> I have a public transport network with an arc for 2 Point(the bus stop).
>>> I'd know without using the points information arc direction like in qgis
>>> (as you can see from the attached imagine with arc_id and direction)
>>> 2013/5/14 Nicolas Ribot <nicolas.ribot at gmail.com
>>> <mailto:nicolas.ribot at gmail.**com <nicolas.ribot at gmail.com>>>
>>> Hi,
>>> If you want to materialize direction from start to end of line, you
>>> can use st_startPoint and st_endpoint to determines the right ends.
>>> What is your use case ?
>>> Nicolas
>>> On 14 May 2013 13:49, franco base <frenk.calza at gmail.com
>>> <mailto:frenk.calza at gmail.com>**> wrote:
>>> Hi.
>>> I know tgis function but doesn't work.
>>> Myabe my question isn't correct.
>>> I'd have a binary value according to the arc direction.
>>> For example, in qgis I can view this information:
>>> I can see an arrow on my arc according to direction.
>>> I'd have the same using postgis.
>>> Thanks
>>> 2013/5/14 Paolo Corti <pcorti at gmail.com <mailto:pcorti at gmail.com
>>> On Tue, May 14, 2013 at 6:03 PM, franco base
>>> <frenk.calza at gmail.com <mailto:frenk.calza at gmail.com>**>
>>> wrote:
>>> > Hi.
>>> > I have a question for the list.
>>> > Is there a postgis function to have line direction?
>>> http://postgis.refractions.**net/docs/ST_Azimuth.html<http://postgis.refractions.net/docs/ST_Azimuth.html>
>>> regards
>>> p
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
>>> ______________________________**_________________
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> <mailto:postgis-users at lists.**osgeo.org<postgis-users at lists.osgeo.org>
>>> http://lists.osgeo.org/cgi-**bin/mailman/listinfo/postgis-**
>>> users <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
>>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.**
>>> osgeo.org <postgis-users at lists.osgeo.org>>
>>> http://lists.osgeo.org/cgi-**bin/mailman/listinfo/postgis-**users<http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131004/b345634a/attachment.html>
