[postgis-users] [postgis-devel] ST_Union() performance problem (with possible funding)
Bborie Park
dustymugs at gmail.com
Wed Oct 16 17:28:27 PDT 2013
Your best bet is to consider splitting the workload among several
postgresql connections.
darkblueb had a blog post about this...
http://blog.light42.com/wordpress/?p=23
On Wed, Oct 16, 2013 at 5:21 PM, Brent Wood <pcreso at pcreso.com> wrote:
> Hi,
> Any advice appreciated!!
> I'm undertaking a spatial analysis using Postgis (what else would I
> use!!!). The first part works well.
> I take a large number (potentially millions) of lines defined by start &
> end points & buffer them to create polygons. (I'm working in lat/long
> EPSG:4326 but transforming to a custom equal area projection for the
> buffering operation).
> I generate a grid of 5x5km cells (polygons) covering the region of
> interest.
> I clip the line based polygons to the grid, so I can generate statistics
> for each cell describing the lines that intersect with it, various
> quantitative measures such as ST_Union() the clipped line polygons to
> generate a footprint in each cell to work out how much is/is not covered,
> or sum the ST_Area() of the clipped polygons grouped by cell to calculate
> an aggregate cover, which can be several times the actual cell area.
> So far so good, it works well, the code is clear & transparent & provides
> a good result. At least as good as any commercial software can do. My test
> data subset is processed from scratch in about 30 minutes.
> Now I want to ST_Union() all the cell based polygons into an overall
> single multipolygon representing the footprint. The code is simple. The
> performance, even with my subset, is a problem.
> I have thousands of cell based footprint multipolygons, each potentially
> with thousands of vertices to be ST_Union()ed. Runtime is weeks for an
> iteration. If I need separate total footprints for 20 different species
> annually for 5 years, that is 100 iterations. Memory & I/O use is minimal -
> it is totally cpu bound.
> I am looking at trying to simplify the polygons to be unioned to reduce
> the number of vertices (& hence processing) involved, but to achieve any
> significant benefit I'm having to change the shape of the polygons to
> ST_Union() too much.
> Does anyone have any suggestions as to how this could be made
> significantly faster?
> If I had $$ to throw at developers to work on the codebase (presumably
> GEOS?) could performance be significantly improved?
> Thanks,
> Brent Wood
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131016/2bf3763b/attachment.html>
