[postgis-users] PostGIS Raster Area from a Clip
Marcello Benigno
benigno.marcello at gmail.com
Tue Oct 22 17:35:09 PDT 2013
Just complementing ...
In my case there is no overlap in any of the layers, there really was no
need ST_Union.
Thanks again for the help and the discussion.
Regards,
2013/10/22 Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> > Won't that only yield the same answer if you can guarantee no overlapping
> > geometries in the fazendas table? My understanding was that the other
> > table was the raster table (which it is reasonable to assume has no
> > overlaps), but we don't know if that's the case with this one.
> Right. But you generally have to have a minimal knowledge about the
> topology of a layer when you query it. Querying a layer with overlaps is
> never the same as querying a layer without.
> So if you know your fazendas layer has overlaps it is a good idea to use
> ST_Union but that means you are getting stats about the global farming area
> not about each farming area. What about areas overlapping? Should they
> count twice? Do these overlaps make sense in reality? Maybe you have to fix
> then first...
> Pierre
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
*Marcello Benigno B. de Barros Filho*
Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
http://profmarcello.blogspot.com
http://about.me/marcello.benigno
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131022/ff3000d0/attachment.html>
