[postgis-users] How to cast a 16BUI to a 32BF raster?
Guido LEMOINE
guido.lemoine at jrc.ec.europa.eu
Wed Oct 23 07:29:57 PDT 2013
Dear List,
First of all, I wish to congratulate the postgis developers with the (new to
me) raster functionality. It's a real game changer.
I am experimenting with (free!) Landsat-8 data, generating indices through
queries. Landsat-8 bands come as 16BUI type data.
In order to avoid integer division issues, I cast to 32BF as follows:
select st_reclass(rast, '0-65535:0-65535', '32BF') from l8tiled where rid =
5644 -- l8tiles holds the tiled single-band rasters, rid is an arbitrary
tile ID
OR
select st_mapalgebra(rast, '32BF', '[rast]') from l8tiled where rid = 5644
Both work, with the first being the fastest (because implement directly in
C). 11 and 21 ms for a 64 by 64 pixel tile, respectively (on Linux 64
bit/Dell T7400 PostgreSQL 9.3/Postgis 2.1).
The first is not very elegant, though, as it requires the somewhat awkward
reclassexpr.
Is there a neater way to do this? If I use '' (empty string) for the
reclassexpr, the cast does not work (i.e. the result remains 16BUI).
Guido Lemoine
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131023/1bde3db8/attachment.html>
