[postgis-users] Check If Point Is In New Geometry
Brent Wood
pcreso at pcreso.com
Sun Oct 27 17:46:59 PDT 2013
Tyler,
Convert your 24 hours worth of points to a linestring
Clip the linestring by your polygons to generate separate lines per polygon per entry tinto the polygon
Count the vertices in each linestring to determine how long each period in each polygon was.
The following shell script might give you some ideas... it works fine here, but is a bit simplistic in terms of input data...
Cheers,
Brent Wood
#! /bin/bash
# gps points to track, clipped by polygons, B Wood, Oct 2013
# create new database to test
dropdb gps
createdb gps
psql -d gps -c "create extension postgis;"
# create table with some gps points
psql -d gps -c "create table gps_points
(id serial primary key,
user_id integer,
point_time timestamp,
gps_point geometry(point,4326));"
psql -d gps -c "insert into gps_points values
(default,
1,
'2013-10-01 00:00:00'::timestamp,
ST_SetSRID(ST_MakePoint(0.0,0.0),4326));"
(default,
1,
'2013-10-01 00:00:01'::timestamp,
ST_SetSRID(ST_MakePoint(0.01,0.01),4326));"
(default,
1,
'2013-10-01 00:00:02'::timestamp,
ST_SetSRID(ST_MakePoint(0.02,0.02),4326));"
(default,
1,
'2013-10-01 00:00:03'::timestamp,
ST_SetSRID(ST_MakePoint(0.03,0.03),4326));"
(default,
1,
'2013-10-01 00:00:04'::timestamp,
ST_SetSRID(ST_MakePoint(0.04,0.04),4326));"
(default,
1,
'2013-10-01 00:00:05'::timestamp,
ST_SetSRID(ST_MakePoint(0.05,0.05),4326));"
(default,
1,
'2013-10-01 00:00:06'::timestamp,
ST_SetSRID(ST_MakePoint(0.06,0.06),4326));"
(default,
1,
'2013-10-01 00:00:07'::timestamp,
ST_SetSRID(ST_MakePoint(0.07,0.07),4326));"
(default,
1,
'2013-10-01 00:00:08'::timestamp,
ST_SetSRID(ST_MakePoint(0.08,0.08),4326));"
(default,
1,
'2013-10-01 00:00:09'::timestamp,
ST_SetSRID(ST_MakePoint(0.09,0.09),4326));"
(default,
1,
'2013-10-01 00:00:10'::timestamp,
ST_SetSRID(ST_MakePoint(0.10,0.10),4326));"
(default,
1,
'2013-10-01 00:00:11'::timestamp,
ST_SetSRID(ST_MakePoint(0.11,0.11),4326));"
(default,
1,
'2013-10-02 00:00:10'::timestamp,
ST_SetSRID(ST_MakePoint(0.12,0.12),4326));"
# create table & some polygons
psql -d gps -c "create table polygons
( id serial primary key,
name varchar(10),
poly geometry(POLYGON,4326));"
psql -d gps -c "insert into polygons values
(default,
'poly1',
ST_PolygonFromText(
'POLYGON((0.0 0.0, 0.0 0.05, 0.05 0.05, 0.05 0.0, 0.0 0.0))',4326));"
(default,
'poly2',
ST_PolygonFromText(
'POLYGON((0.05 0.05, 0.05 0.1, 0.1 0.1, 0.1 0.05, 0.05 0.05))',4326));"
# query to get trackline
psql -d gps -c "create table trackline as
SELECT gps.user_id,
gps.point_time::date as track_date,
ST_MakeLine(gps.gps_point) as trackline
FROM (SELECT user_id, gps_point, point_time
FROM gps_points
WHERE user_id = 1
AND point_time::date = '2013-10-01'::date
ORDER BY point_time) as gps
GROUP BY gps.user_id,
track_date;"
# get intersections
psql -d gps -c "create table segments as
SELECT t.user_id,
t.track_date,
p.name,
ST_Intersection(t.trackline, p.poly) as segment
FROM trackline t,
polygons p;"
# get time of arrival & no minutes in each polygon
psql -d gps -c "SELECT s.user_id,
s.name,
s.track_date,
min(g.point_time) as arrival_time,
(ST_NPoints(segment)/60.0)::decimal(6,2) as minutes
FROM segments s,
gps_points g
WHERE ST_intersects(g.gps_point,s.segment)
GROUP BY s.id,
s.user_id,
s.name,
s.track_date
ORDER BY arrival_time;"
From: Tyler DeWitt <tyler.scott.dewitt at gmail.com>
To: postgis-users at lists.osgeo.org
Sent: Monday, October 28, 2013 7:52 AM
Subject: [postgis-users] Check If Point Is In New Geometry
I have a table of geometries (with a geom column of type MultiPolygon Z).
I collect real time location data (1 point a second) and store that in a tracked_points table (with a geom column of type PointZ, and user_id column of type int).
I'd like to know when a user (tracked by their point) enters a new/different geometry.
I can use ST_Contains(geometries.geom, tracked_points.geom) to figure out which geometry a user is currently in, but I'd like to find an efficient way to check a 24 hour period and say "User 1 went from geometry A to geometry B to Geometry C and back to Geometry B". I could find how many points a user has in each geometry, and therefore how long they spent in each geometry, but I don't know about the path the user took.
Thanks,
Tyler
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131027/ec4c40d6/attachment.html>
