[postgis-users] st_split
Rémi Cura
remi.cura at gmail.com
Mon Oct 28 10:20:47 PDT 2013
Hey, you may want to use a function I wrote as a wrapper around ST_Split to
allow splitting a (multi-)line with (multi) points.
Here it is.
It still thinks it should be somewhere is the core.
Cheers,
Rémi-C
--creating a simple wrapper around ST_Split to allow splitting line by
multipoints
DROP FUNCTION IF EXISTS public.Split_multi(input_geom geometry ,blade
geometry);
CREATE FUNCTION public.Split_multi(input_geom geometry ,blade geometry)
RETURNS geometry AS
$BODY$
--this function is a wrapper around the function ST_Split to allow
splitting mutli_lines
with multi_points
DECLARE
result geometry;
simple_blade geometry;
blade_geometry_type text := GeometryType(blade); geom_geometry_type text :=
GeometryType(input_geom);
blade_coded_type SMALLINT; geom_coded_type SMALLINT;
BEGIN
--finding type of input : mixed type are not allowed
--if type is not multi, simply splitting and returning result
IF blade_geometry_type NOT ILIKE 'MULTI%' THEN
--RAISE NOTICE 'input geom is simple, doing regular split';
RETURN ST_Split(input_geom,blade);
ELSIF blade_geometry_type ILIKE '%POINT' THEN
blade_coded_type:= 1;
ELSIF blade_geometry_type ILIKE '%LINESTRING' THEN
blade_coded_type:= 2;
ELSIF blade_geometry_type ILIKE '%POLYGON' THEN
blade_coded_type:= 3;
ELSE
RAISE NOTICE 'mutliple input geometry types for the blade : should be
homogenous ';
RETURN NULL;
END IF;
IF geom_geometry_type ILIKE '%POINT' THEN
geom_coded_type:= 1;
ELSIF geom_geometry_type ILIKE '%LINESTRING' THEN
geom_coded_type:= 2;
ELSIF geom_geometry_type ILIKE '%POLYGON' THEN
geom_coded_type:= 3;
ELSE
RAISE NOTICE 'mutliple input geometry types for the geom: should be
homogenous ';
RETURN NULL;
END IF;
result := input_geom;
--Loop on all the geometry in the blade
FOR simple_blade IN SELECT (ST_Dump(ST_CollectionExtract(blade,
blade_coded_type))).geom
LOOP
result:=
ST_CollectionExtract(ST_Split(result,simple_blade),geom_coded_type);
END LOOP;
RETURN result;
END;
$BODY$
LANGUAGE plpgsql IMMUTABLE;
--Testing the function
SELECT ST_AsText(Split_multi(geom, blade))
FROM (
SELECT ST_GeomFromText('Multilinestring((-3 0, 3 0),(-1 0,1 0))') AS geom,
ST_GeomFromText('MULTIPOINT((-0.5 0),(0.5 0))') AS blade
--ST_GeomFromText('POINT(-0.5 0)') AS blade
--ST_GeomFromText('MULTILINESTRING((0 1, 0 -1),(0 2,0 -2))') AS blade
--ST_GeomFromText('MULTIPOLYGON(((0 1,0 -1 ,1 -1,0 1)),((0 2,0 -2,1 -2,0
2)))') AS blade
) AS toto
2013/10/28 franco base <frenk.calza at gmail.com>
> Hi.
> I have a set of linestring and point on linestring.
> I want cut the linestring on the point.
> I can have n points for one linestring,
> so I use ST_Split
> (insted of ST_Line_Interpolate_Point and ST_Line_Substring)
> but it doesn't work.
> line;geom_line;point;geom_point
> 7646;"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE33534123B9FC675020374112143FF6BC335341";11764;"0101000020BB0B00005713362F611F37410D996234AF335341"
> 7646;"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE33534123B9FC675020374112143FF6BC335341";11769;"0101000020BB0B00005EF0DD584620374139BF2762BC335341"
> 7646;"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE33534123B9FC675020374112143FF6BC335341";11762;"0101000020BB0B0000A5CBC785841F374156A2A33CB1335341"
> ST_GeometryType(St_Split(geom_line, geom_point))
> give "ST_GeometryCollection"
> but
> (ST_Dump(ST_Split(geom_line, geom_point))).geom
> return only 3 linestring (one for record) and the geometry is egual to
> geom_line
> thanks.
> fb
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131028/e87d9d96/attachment.html>
