[postgis-users] st_split
Rémi Cura
remi.cura at gmail.com
Tue Oct 29 04:51:24 PDT 2013
Do you really need st_intersects?
Can you use ST_Dwithin(point, line, your_precision) instead?
Cheers,
Rémi-C
2013/10/29 franco base <frenk.calza at gmail.com>
> Thanks Remi
> You are very clear now.
> Meanwhile I make some test and I think there is a bug somewhere.
> I use the ST_ClosestPoint example documenation
> SELECT ST_AsText(ST_ClosestPoint(pt,line)) AS cp_pt_line,
> ST_AsText(ST_ClosestPoint(line,pt)) As cp_line_pt,
> ST_Contains(line, ST_ClosestPoint(line,pt)), --- f
> ST_Intersects (line, ST_ClosestPoint(line,pt)), --- f
> ST_Distance (line, ST_ClosestPoint(line,pt)), ---- 0
> ST_Line_Locate_Point (line, ST_ClosestPoint(line,pt)) ---
> return value
> FROM
> (SELECT 'POINT(100 100)'::geometry As pt,
> 'LINESTRING (20 80, 98 190, 110 180, 50 75 )'::geometry
> As line ) As foo
> give this output:
> "cp_pt_line";"cp_line_pt";"st_contains";"st_intersects";"st_distance";"st_line_locate_point"
> "POINT(100 100)";"POINT(73.0769230769231
> 115.384615384615)";f;f;0;0.828619715102687
> Something is wrong
> 2013/10/29 Rémi Cura <remi.cura at gmail.com>
>> Hey sorry for being unclear.
>> I put you a pseudo code and some explanation :
>> - first you work with real world data (observation, measure), which
>> are of a given precision (showing the uncertainty of the measure).
>> If your data are real world observation ,they may be precise up to
>> the centimeter, the meter , whatever. So there is no significance of
>> keeping XXX digits after the comma.
>> - Second about translating : for your computer manipulating a number
>> like 650254,2354 is not the same as manipulating a number like 254,2354.
>> Numbers are represented with double precision, which can be precise
>> up to* 15 digits *thanks to postgres. Keeping the number of digits
>> low in your coordinates "free" some precision for computing. You can
>> translate by any number as long as it reduce the number of digits in the
>> coordinates.
>> You can also manually translate like : x := x - 859 ; y:= y - 87426.
>> - Third : about ST_ClosestPoint : if you point are a result of a
>> previous computing, they are already of limited precision, thus you have to
>> compensate this by manually putting the points onto the lines (using
>> ST_ClosestPoint will give you a new point corresponding to old point
>> projected onto line).
>> Here is the pseudo code
>> --if your data are of limited precision (always the case ! )
>> snap to grid (your data precision)
>> --before computation
>> translate everyting (-(min_x+max_x)/2, -(min_y+max_y)/2)
>> --computation : do your spatial test
>> --if precision issue not solved, use ST_ClosestPoint to project your
>> point onto lines
>> --after computation
>> translate everyting (+(min_x+max_x)/2, +(min_y+max_y)/2)
>> Cheers,
>> Rémi-C
>>> Ayway
>>> St_split and St_snap don't work
>>> SELECT line,
>>> point,
>>> st_contains (st_snap (geom_line, geom_point,0.001), geom_point),
>>> st_geometrytype ((st_dump(ST_split(st_snap (geom_line,
>>> geom_point,0.001), geom_point))).geom),
>>> (st_dump(ST_split(st_snap (geom_line, geom_point,0.001),
>>> geom_point))).geom as splitted_geometry
>>> give
>>> "id";"line";"point";"st_contains";"st_geometrytype";"splitted_geometry"
>>> 1;7646;11764;t;"ST_LineString";"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE3353415713362F611F37410D996234AF335341"
>>> 2;7646;11764;t;"ST_LineString";"0102000020BB0B0000020000005713362F611F37410D996234AF33534123B9FC675020374112143FF6BC335341"
>>> 3;7646;11769;t;"ST_LineString";"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE3353415EF0DD584620374139BF2762BC335341"
>>> 4;7646;11769;t;"ST_LineString";"0102000020BB0B0000020000005EF0DD584620374139BF2762BC33534123B9FC675020374112143FF6BC335341"
>>> 5;7646;11762;t;"ST_LineString";"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE335341A5CBC785841F374156A2A33CB1335341"
>>> 6;7646;11762;t;"ST_LineString";"0102000020BB0B000002000000A5CBC785841F374156A2A33CB133534123B9FC675020374112143FF6BC335341"
>>> St_geometrytype=ST_LineString but in qgis I have point and line.
>>> point splitted geometry (id =2,4,6) = geom_point (starting gometry)
>>> line splitted geometry (id =1,3,5) = geom_line (starting gometry)
>>>> Hi.
>>>> Yes the cause can be that every function has his own "tolerance"
>>>> SELECT line,geom_line,point,geom_point,
>>>> ST_ClosestPoint(geom_line,geom_point), ----- return geometry=geom_point
>>>> ST_distance (geom_line,geom_point), ---- return 0
>>>> ST_contains(geom_line,geom_point) ---- return false
>>>> "line";"geom_line";"point";"geom_point";"st_closestpoint";"st_distance";"st_contains"
>>>> 7646;"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE33534123B9FC675020374112143FF6BC335341";11764;"0101000020BB0B00005713362F611F37410D996234AF335341";"0101000020BB0B00005713362F611F37410D996234AF335341";0;f
>>>> 7646;"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE33534123B9FC675020374112143FF6BC335341";11769;"0101000020BB0B00005EF0DD584620374139BF2762BC335341";"0101000020BB0B00005EF0DD584620374139BF2762BC335341";0;f
>>>> 7646;"0102000020BB0B000006000000A4703D0A471F37412D211F04AF335341FAEDEBE0491F3741325530C2AE335341BD5296014F1F37418FC2F578AE3353414694F606521F3741D2DEE07BAE3353412D211F74541F37418FC2F578AE33534123B9FC675020374112143FF6BC335341";11762;"0101000020BB0B0000A5CBC785841F374156A2A33CB1335341";"0101000020BB0B0000A5CBC785841F374156A2A33CB1335341";0;f
>>>> Remi I don't undesrtand very well your tip to translate date and use
>>>> St_SnapToGrid
>>>> I cannot snap (using St_Snap) line to point because I'm working on a
>>>> road network and I cannot move the line versus point.
>>>> Thanks
>>>> fb
>>>> 2013/10/28 Rémi Cura <remi.cura at gmail.com>
>>>>> I had the same problem,
>>>>> all function don't react the same way when hitting precision limit.
>>>>> You may want to translate your data to reduce digits, and/or use
>>>>> ST_SnapToGrid on everything before using ST_ClosestPoint.
>>>>> Cheers,
>>>>> Rémi-C
>>>>> 2013/10/28 Nicolas Ribot <nicolas.ribot at gmail.com>
>>>>>> Hmm this is strange:
>>>>>> Finding the closest point (st_closestPoint) or using
>>>>>> st_lineLocatePoint to project point onto the line does not work either
>>>>>> on the provided dataset.
>>>>>> Though the st_distance(line, point) returns 0.
>>>>>> Nicolas
>>>>>> On 28 October 2013 18:42, Rémi Cura <remi.cura at gmail.com> wrote:
>>>>>> > You may want to split not with point but with the projected point
>>>>>> one line
>>>>>> > (use http://postgis.refractions.net/docs/ST_ClosestPoint.html)
>>>>>> > If it is not enough, you may want to translate all your geometries
>>>>>> to reduce
>>>>>> > the number of digits in coordinates.
>>>>>> > Another possibility is to use ST_Snap to snap line to point (won't
>>>>>> work the
>>>>>> > other way)
>>>>>> > Cheers,
>>>>>> > Rémi-C
>>>>>> >> Hi,
>>>>>> >> The points are not on the line, probably due to rounding errors.
>>>>>> >> st_contains(line, point) returns false.
>>>>>> >> Nicolas
>>>>>> >> On 28 October 2013 18:07, franco base <frenk.calza at gmail.com>
>>>>>> wrote:
>>>>>> >> > Hi.
>>>>>> >> > I have a set of linestring and point on linestring.
>>>>>> >> > I want cut the linestring on the point.
>>>>>> >> > I can have n points for one linestring,
>>>>>> >> > so I use ST_Split
>>>>>> >> > (insted of ST_Line_Interpolate_Point and ST_Line_Substring)
>>>>>> >> > but it doesn't work.
>>>>>> >> > line;geom_line;point;geom_point
>>>>>> >> > ST_GeometryType(St_Split(geom_line, geom_point))
>>>>>> >> > give "ST_GeometryCollection"
>>>>>> >> > but
>>>>>> >> > (ST_Dump(ST_Split(geom_line, geom_point))).geom
>>>>>> >> > return only 3 linestring (one for record) and the geometry is
>>>>>> egual to
>>>>>> >> > geom_line
>>>>>> >> > thanks.
>>>>>> >> > fb
>>>>>> >> > _______________________________________________
>>>>>> >> > postgis-users mailing list
>>>>>> >> > postgis-users at lists.osgeo.org
>>>>>> >> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131029/3d690783/attachment.html>
