[postgis-users] Problem with pagc_normalize_address() results...
crowmagnumb southerland at samsix.com
Tue Oct 29 19:27:09 PDT 2013
I have installed the adress_standardizer (version 1.0) into a fresh install
of postgresql 9.3.1 with postgis 2.1.0 and I am finding an issue with the
address normalizer.
If I give the following valid address, it works...
db=# select internal, location, stateabbrev from pagc_normalize_address('16
Berry Lane, schenectady, ny 12302');
 internal |  location   | stateabbrev
          | SCHENECTADY | NY
... but if I intentionally misspell schenectady (because I'm trying to get a
function to work using soundex() to allow misspellings), then it doesn't
work ....
Berry Lane, skenectady, ny 12302');
 # SKENECTADY | NEW YORK |
... the misspelled town is put into the internal field and the location
becomes New York spelled out.  But then if I get rid of the comma between
Lane and the town but still misspell it, it parses as I expect...
ksedb=# select internal, location, stateabbrev from
pagc_normalize_address('16 Berry Lane skenectady, ny 12302');
          | SKENECTADY | NY
... with the location being the incorrectly spelled town name.
Any ideas why this subtle difference occurs?
View this message in context: http://postgis.17.x6.nabble.com/Problem-with-pagc-normalize-address-results-tp5004678.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
