[postgis-users] Wiki editing (was: spatial index for topology?)
Sandro Santilli
strk at keybit.net
Wed Oct 30 05:55:33 PDT 2013
On Wed, Oct 30, 2013 at 01:36:23PM +0100, Rémi Cura wrote:
> Hey,
> done for the anoying "PostGis".
> regarding topology, I always use ::geometry , so using topology is using
> plain PostGIS geometry for me.
> Do you have something specific in mind?
As of QGIS-2.0.0 there's:
- Native support for TopoGeometry layers (no need to make a query,
"Add PostGIS Layer" will let you select TopoGeometry fields)
- Topology viewer in DBManager: select a topology schema and see
view topology (or similar) in the menu.
- A postgis topology editor plugin (Experimental)
--strk;
