[postgis-users] New function ST_DumpSegments?? (was : utility function : linestring -> setof segment)
Rémi Cura remi.cura at gmail.com
Wed Oct 30 06:56:47 PDT 2013
Yep,
would need some wrapping to output right path :-)
I'd really like to have more functions in PostGis...
I'm not going to do it yet, working on a SnapToLine function.
Cheers,
Rémi-C
2013/10/30 Nicolas Ribot <nicolas.ribot at gmail.com>
> Hi,
> To dump (multi)polygons boundaries, you can use:
> st_exteriorRing((st_dumpRings((st_dump(geom)).geom)).geom)
> I returns one linestring for each boundary, taking holes into account.
> Nicolas
> On 30 October 2013 14:34, Rémi Cura <remi.cura at gmail.com> wrote:
> > Hey,
> > here is the function, safe for geometry collection and multilinestring as
> > well.
> > It mimics ST_DumpPoints.
> > It doesn't work on polygon as we would first need a method STDumpLines.
> > Origine of segments is preserved inside the path when multi.
> > Could it be added to core ?
> > Shall I add a ticket?
> > Cheers,
> > Rémi-C
> > DROP FUNCTION IF EXISTS public.DumpSegments(line geometry ) ;
> > CREATE OR REPLACE FUNCTION public.DumpSegments(_line geometry)
> > RETURNS SETOF geometry_dump
> > AS
> > $BODY$
> > --this function breaks a line into minimal segments and return it
> > DECLARE
> > _r record;
> > BEGIN
> > FOR _r in SELECT ST_Dump(ST_CollectionExtract (_line,2)) AS dp
> > LOOP
> > RETURN QUERY WITH line AS(
> > SELECT --ST_GeomFromText('LINESTRING(12 1, 13 1, 14 2, 15 4)') AS line
> > (_r.dp).path AS gpath, (_r.dp).geom AS line
> > dump AS(
> > SELECT gpath[1] AS gpath, (ST_DumpPoints(line)) as dp
> > FROM line
> > segments AS (
> > SELECT CASE WHEN gpath IS NULL THEN ARRAY[(dp).path[1]-1] ELSE
> ARRAY[gpath,
> > (dp).path[1]-1] END AS path,ST_MakeLine( lag((dp).geom , 1, NULL) OVER
> > (ORDER BY  (dp).path),(dp).geom) AS geom
> > FROM dump
> > SELECT path,geom
> > FROM segments
> > WHEre geom  IS NOT NULL;
> > END LOOP;--loop if multi linestring
> > RETURN;
> > END;
> > $BODY$
> >  LANGUAGE plpgsql  IMMUTABLE STRICT;
> > SELECT public.DumpSegments(line2)
> > FROM ST_GeomFromText('MULTILINESTRING((12 1, 13 1, 14 2, 15 4),(1 1, 2
> 2,3
> > 3))') AS line1,ST_GeomFromText( 'LINESTRING(12 1, 13 1, 14 2, 15 4)') AS
> > line2
> > 2013/10/30 Rémi Cura <remi.cura at gmail.com>
> >> Thanks,
> >> wanted to do it the clean way (geos accelerated maybe?),
> >> but not so much a big deal, I'll go you way.
> >> Cheers,
> >> Rémi-C
> >>> Hi,
> >>> I don't think such a function exists in postgis.
> >>> (To achieve that, I usually dump line points and create new
> >>> linestrings with vertices n, n+1)
> >>> Nicolas
> >>> On 30 October 2013 10:59, Rémi Cura <remi.cura at gmail.com> wrote:
> >>> > Hey,
> >>> > is somebodyers aware of a function breaking a linestring into a set
> of
> >>> > segments (mathematical meaning),
> >>> > without introducing new points?
> >>> > Cheers,
> >>> > Rémi-C
> >>> > _______________________________________________
> >>> > postgis-users mailing list
> >>> > postgis-users at lists.osgeo.org
> >>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131030/2c110e59/attachment.html>
