[postgis-users] AsTopoJSON fails with: "No function matches the given name and argument types."
Luca Morandini
lmorandini at ieee.org
Thu Sep 5 00:09:36 PDT 2013
Folks,
I have hard-upgraded a database to POstGIS 2.1 (on PostgreSQL 9.1), built a
topology with ToTopoGeom and obtained this nice table:
Table "abs_asgc.lga06aaustlines"
Column | Type | Modifiers
gid | integer | not null default
nextval('abs_asgc.lga06aaustlines_gid_seq'::regclass)
ogc_fid | integer |
topology | topogeometry |
Indexes:
"lga06aaustlines_pkey" PRIMARY KEY, btree (gid)
Check constraints:
"check_topogeom_topology" CHECK ((topology).topology_id = 2 AND
(topology).layer_id = 1 AND (topology).type = 3)
But when I try to use the tpology column, like in:
select ST_AsTopoJSON(topology) from abs_asgc.lga06aaustlines;
It doesn't seem to like it :|
As far as I can see, topology is a TopoGeometry column, which is what this
function expects... so, What am I doing wrong ?
Regards,
Luca Morandini
Data Architect - AURIN project
Melbourne eResearch Group
Department of Computing and Information Systems
University of Melbourne
Tel. +61 03 903 58 380
Skype: lmorandini
