[postgis-users] ssh tunneling from QGIS ?
didier peeters
dpeeter1 at ulb.ac.be
Wed Sep 18 11:47:36 PDT 2013
Dan, I don't know if this would clutter up QGis, I'm not competent enough for this. Personally I don't have any problem with opening a ssh tunnel with a command line, I'm a unix user (Mac) and I do it every day. But I have lots of colleagues for whom this is far too 'complicated', especially on windows. If there was a ssh tunnel option in the DB connection properties, I could show them to use it or save an xml file with it and tell them to load it inside QGis.
Didier
Le 18 sept. 2013 à 19:56, Dan Lyke <danlyke at flutterby.com> a écrit :
> On Wed, Sep 18, 2013 at 10:50 AM, didier peeters <dpeeter1 at ulb.ac.be> wrote:
>> is there any plan to have in QGis (in DB Manager maybe) the
>> ability to connect to a postgis server through a ssh tunnel ?
> Why would you clutter up QGIS with that rather than just making your
> own startup script for QGIS that spawned an auto-ssh process, and
> specifying the port in your database connection?
> Dan
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
