[postgis-users] installing 2.1
Devrim GÜNDÜZ
devrim at gunduz.org
Thu Sep 19 03:09:36 PDT 2013
On Wed, 2013-09-18 at 17:23 -0400, Stephen Crawford wrote:
> In the midst of a hard upgrade to 2.1. Installed postgres 9.3 and
> postGIS 2.1. I have created a new database. Now when i try to load
> "postgis.sql" into new DB I get this error early on:
> psql:postgis.sql:58: ERROR: could not load library
> "/usr/pgsql-9.3/lib/postgis-2.1.so": /usr/pgsql-9.3/lib/postgis-2.1.so:
> undefined symbol: pj_get_spheroid_defn
> I can see that the library is in the correct location. Any thoghts?
Looks like you are using the RPMs -- please make sure that you updated
all packages, including proj and GEOS, which are built with PostgreSQL
9.3
Regards,
Devrim GÜNDÜZ
Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130919/5d750d47/attachment-0001.pgp>
