[postgis-users] installing 2.1
Stephen Crawford src176 at psu.edu
Thu Sep 19 09:37:32 PDT 2013
We are running Centos 6, postgres 9.3.  We have GDAL 1.9 installed.
I'm doing a hard upgrade.  We had postgres 8.4 with postgis 2.0 and it
was working.
On 9/19/2013 12:03 PM, Devrim Gündüz wrote:
> Hi,
> Is this RHEL 6? If so, raster support is not available due to old gdal
> version :-(
> Regards,
> Stephen Crawford <src176 at psu.edu> wrote:
>     Now I have added postgis.sql to my new DB, but I can't seem to find
>     rtpostgis.sql to add raster support.  I expected it to be in
>     /usr/pgsql-9.3/share/contrib/postgis-2.1/ alongside postgis.sql and
>     topology.sql, etc.
>     Any thoughts?
>     Thanks Again,
>     Steve
>     On 9/19/2013 10:36 AM, Stephen Crawford wrote:
>         That was it, the dynamic link was looking at the remnants of
>         the previous build. Thanks. On 9/19/2013 4:00 AM, Sandro
>         Santilli wrote:
>             On Wed, Sep 18, 2013 at 05:23:29PM -0400, Stephen Crawford
>             wrote:
>                 Hi All, In t! he midst of a hard upgrade to 2.1.
>                 Installed postgres 9.3 and postGIS 2.1. I have created
>                 a new database. Now when i try to load "postgis.sql"
>                 into new DB I get this error early on:
>                 psql:postgis.sql:58: ERROR: could not load library
>                 "/usr/pgsql-9.3/lib/postgis-2.1.so
>                 <http://postgis-2.1.so>":
>                 <http://postgis-2.1.so>: undefined symbol:
>                 pj_get_spheroid_defn I can see that the library is in
>                 the correct location. Any thoghts?
>             Do you have multiple versions of proj4 library installed
>             on the system ? It looks like PostGIS was built against a
>             version with the "pj_get_spheroid_defn" function but the
>             dynamic linker isn't finding that same version. --strk;
>             postgis-users mailing list postgis-users at lists.osgeo.org
>             http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>     Stephen Crawford
>     Center for Environmental Informatics
>     The Pennsylvania State University
>     src176 at psu.edu
>     814.865.9905
> Devrim Gündüz
Stephen Crawford
src176 at psu.edu
814.865.9905
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130919/46399ce1/attachment.html>
