[postgis-users] k-shortst paths
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Sep 23 06:25:49 PDT 2013
Tina,
you should be asking this question on the Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
If you look in github
https://github.com/pgRouting/pgrouting/tree/master/src/ksp/test
there are tests for all the code, load the *.data file, then look at the
*.test files and you can run them.
Docs are here
http://docs.pgrouting.org/
See you on the other list.
-Steve
On 9/23/2013 8:57 AM, Tina Musa wrote:
> Hello,
> I see in pg routing web site that provide Yen algorithm function.
> I try to run the algorithm but it's impossible to do.
> Can you tell me the steps that i can do to run the algorithm successfully?
> Thank you in advance
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
