[postgis-users] (no subject)
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Sep 23 06:56:47 PDT 2013
You can use ST_NotSameAlignmentReason() to determine how the two rasters are not aligned...
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-
> bounces at lists.osgeo.org] On Behalf Of Hugues François
> Sent: Monday, September 23, 2013 3:13 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] (no subject)
> Hello,
> Your pixels are not aligned... This should have several causes. If you worked
> with rasters you choose to tile, this may comes from transformation (since
> version 2.1 you can choose a reference tile). If not, we will need more
> information about your rasters to help you.
> Hugues.
> ________________________________
> bounces at lists.osgeo.org] On Behalf Of Ahmet Temiz
> Sent: Monday, September 23, 2013 8:52 AM
> Subject: [postgis-users] (no subject)
> hello
> I got this error message.
> rt_raster_iterator: The set of rasters provided (custom extent included, if
> appropriate) do not have the same alignment.
> what is the likely cause of this problem ?
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Afet ve Acil Durum Yönetimi Başkanlığı
> Planlama ve Zarar Azaltma Dairesi Başkanlığı
> Ahmet Temiz
> Geological Eng.
> Information Systems - GIS Group
> Disaster and Emergency Management
> of Presidency
