[postgis-users] error loading shapefiles into postgis
Clay, Bruce
bclay at ball.com
Thu Sep 26 12:42:11 PDT 2013
I have a number of shapefiles from various sources that have a mixture of polygons and multi-polygons or points nad multi-point that I have been trying to load into PostGis. I have tried using QGis / Spit, org2ogr and shp2pgsql.
Some of the files will load but thow a bunch or errors/warnings and others won't load at all. The files are part of the ArcGis data distribution as sdc files converted to shapefiles using the ESRI DDA application.
Is there a "proper method" or any method that will work to get the data registered in PostGis?
Bruce
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130926/9e32639e/attachment.html>
