[postgis-users] About 2-dimensional arrays of postgresql
Miguel-Angel Manso-Callejo (UPM)
m.manso at upm.es
Thu Sep 26 23:25:23 PDT 2013
Dear all,
I'm writing a stored procedure (pgplSQL) that uses postgis functions
version 2.1
Dump the contents of an image on a two-dimensional array and then I
update the cells according to some calculations.
The process is slow, but after a while I discovered devote to the
problem, or the slowness is due to operations that read and update the
two-dimensional array.
The code is roughly this:
DECLARE
*img***double precision [] [];
i integer j integer;
BEGIN
select ST_DumpValues (rast, 1, false) INTO *img***from ..
for i IN 1 .. 1000 LOOP
for j IN 1 .. 500 LOOP
*img***[i] [j]: = ..............;
END LOOP;
END LOOP;
select ST_SetValues (image, 1, 1, 1, *img*) INTO imagen2;
END;
Anyone know why the update of the values of the two-dimensional array is
slow?, Poorly defined array for the type of operations performed?
thank you very much
Best regards.
Miguel A. Manso
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130927/d501d0b9/attachment.html>
