[postgis-users] getting unexpected results on an ST_Intersects query
islanis at infomed.sld.cu
Sat Apr 5 13:37:45 PDT 2014
"Hugues François" <hugues.francois at irstea.fr> escribió:
> Hello,
> It's difficult to give an answer since you don't tell us a lot about
> unexpected results buy you could try something like (will not work
> if a ft_cubo's polygon intersects different sigfre_cub_adm_munic
> polygons) :
ok sorry,
the question is that where for example I should update to an id as 113
or other number, puts me another number like 3, 8 or other, it is very
rare, is that, I have no more details, all the detail is in the query
> UPDATE
> ft_cubo
> SET
> gidmunic = mgid
> FROM (
> SELECT DISTINCT ft_cubo.gid AS cgig, sigfre_cub_adm_munic.gid AS mgid
> FROM sigfre_cub_adm_munic, ft_cubo
> WHERE
> ST_Intersects(ft_cubo.the_geom,sigfre_cub_adm_munic.the_geom)
> ) AS foo
> WHERE gid = cgid
> HTH
> If it's not give the expected results, you can work on the subselect
> query to return the expected unique gid pairs.
> Hugues.
> -----Message d'origine-----
> De : postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] De la part de
> Envoyé : samedi 5 avril 2014 21:28
> À : postgis-users at lists.osgeo.org
> Objet : [postgis-users] getting unexpected results on an ST_Intersects query
> Hi folks, I'm having problems when I try to run a simple query to
> update the gidmunic field of ft_cubo layer, and it assigns a value
> that does not exists in said field, please, i need help , the two
> layers are multipolygon type. what should I do?
> UPDATE
> ft_cubo
> SET
> gidmunic = sigfre_cub_adm_munic.gid
> WHERE
> ST_Intersects(ft_cubo.the_geom,sigfre_cub_adm_munic.the_geom);
> thanks in advance
> This message was sent using IMP, the Internet Messaging Program.
> Este mensaje le ha llegado mediante el servicio de correo
> electronico que ofrece Infomed para respaldar el cumplimiento de las
> misiones del Sistema Nacional de Salud. La persona que envia este
> correo asume el compromiso de usar el servicio a tales fines y
> cumplir con las regulaciones establecidas
> Infomed: http://www.sld.cu/
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
