[postgis-users] [postgis-devel] looking for a public well known maven repository for postgis-jdbc 2.1 and later on versions
Shane StClair
shane at axiomalaska.com
Mon Apr 7 11:26:22 PDT 2014
Hi Baris,
Oops, I didn't see that you were already chasing this down. Your approach
sounds great, thanks for taking the lead on this! In the past there have
been issues with other projects having non-resolvable dependencies on
versions of postgis-jdbc (Hibernate Spatial), so it will be great to have
these artifacts in the central repo.
Best,
Shane
On Sun, Apr 6, 2014 at 2:29 AM, Baris Ergun <barisergun75 at gmail.com> wrote:
> Hi Shane;
> Thanks for ur patch and consideration. I think we are on the same path if
> u check the issue #2626. I have applied the OSSRH and got the credentials
> for being able to upload postgis jdbc jars to central maven rep. For that
> case I have separated the jdbc and jdbc-jtsparser jars on the trunk and
> updated the pom.xml's according to Central maven repository requirements..
> On the trunk actually I was waiting to agree with all the developers to
> separate the postgis jdbc jars repository and continue with 1st suggested
> approach. If we do that way we wouldnt need to make the explicit plugin
> declarations as you patched in 2702.
> Here is my proposal: I can take care of the last targeted 2.1 release
> which is 2.1.3 and change pom.xmls as I did in the trunk and apply shanes
> patches and after the release of 2.1.3 I can manually sign the jars and
> submit them to OSSRH. And keep discussing the separation of repositories on
> trunk.
> On 6 April 2014 05:32, Paragon Corporation <lr at pcorp.us> wrote:
>> I don't have any objections. +1 for that.
>> Thanks,
>> Regina
>> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
>> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Shane StClair
>> *Sent:* Saturday, April 05, 2014 5:24 PM
>> *To:* PostGIS Users Discussion
>> *Cc:* PostGIS Development Discussion
>> *Subject:* Re: [postgis-users] looking for a public well known maven
>> Sounds good. Any objection to the community manually uploading pre-2.2
>> versions to Maven Central?
>> Thanks,
>> Shane
>> On Sat, Apr 5, 2014 at 1:38 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>> Shane,
>>> I think we can change our build bot to upload to maven as part of the
>>> official release job when we build tagged docs etc. Have to talk over with
>>> rest of PostGIS psc and dev folks on that.
>>> I guess before that we'll need to completely cleanup the issues with our
>>> current jdbc which sounds like we are close. Thanks for the patch BTW.
>>> Thanks,
>>> Regina Obe
>>> PostGIS PSC member
>>> http://www.postgis.us
>>> http://postgis.net
>>> *Sent:* Saturday, April 05, 2014 3:29 PM
>>> *To:* postgis-users at lists.osgeo.org
>>> *Subject:* [postgis-users] looking for a public well known maven
>>> I just submitted a patch [1] to generate javadoc and source jars as
>>> part of the postgis-jdbc build. Otherwise, the existing pom meets the Maven
>>> Central sync requirements [2].
>>> There are two options for getting up to date postgis-jdbc releases into
>>> Maven Central. The first would be for Maven Central deployment to become
>>> part of the postgis release process. After the initial setup the Maven
>>> Central publishing process isn't terribly painful, but it would require a
>>> postgis developer to assume responsibility for the Maven Central submission
>>> and for postgis-jdbc to get special consideration during releases [3] [4].
>>> The other option would be to have the community manually upload to Maven
>>> Central [5]. This is definitely not the ideal situation, but if Maven
>>> Central uploads are out of scope for the postgis devs right now it would
>>> allow us to get updated versions into the central repo. A blessing from the
>>> postgis devs would help in this second case.
>>> Thanks,
>>> Shane
>>> [1] http://trac.osgeo.org/postgis/ticket/2702
>>> [2]
>>> https://docs.sonatype.org/display/Repository/Central+Sync+Requirements
>>> [3]
>>> https://maven.apache.org/guides/mini/guide-central-repository-upload.html
>>> [4] http://central.sonatype.org/pages/ossrh-guide.html
>>> [5]
>>> https://docs.sonatype.org/display/Repository/Uploading+3rd-party+Artifacts+to+The+Central+Repository
>>> Shane StClair
>>> Software Engineer
>>> Axiom Consulting & Design
>>> http://www.axiomalaska.com
>>> postgis-users mailing list
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Shane StClair
>> Software Engineer
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> Barış
Shane StClair
Software Engineer
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140407/2dfb999c/attachment.html>
