[postgis-users] problems with 2.1.2 and new databases
Mateusz Łoskot
mateusz at loskot.net
Wed Apr 9 11:04:12 PDT 2014
On 9 April 2014 18:58, Jay Moss <jaymoss3 at gmail.com> wrote:
> 2. spatially enable it using psql and "CREATE EXTENSION postgis".
You need to decide, either you are installing as an extension
> 4. update the postgressql search path to add my new db at the front of
> the list.
> 5. run \share\contrib\postgis-2.1\postgis.sql - FAILS
> 6. run \share\contrib\postgis-2.1\spatial_ref_sys.sql
> 7. run \share\contrib\postgis-2.1\postgis_comments.sql
or you go old fashion and import the scripts manually
These are two different options to choose from.
See http://postgis.net/docs/manual-2.1/postgis_installation.html
Best regards,
Mateusz Łoskot, http://mateusz.loskot.net
