[postgis-users] Which length function should be used for linestrings
Raghavan Krishnasamylakshmanaperumal
rkrish20 at uic.edu
Mon Apr 21 08:25:24 PDT 2014
Hi All,
I am trying to make use of linestring's length for one of my route
detection experiment.
My linestring data is in this format
"the_geom geometry(LineString,4326)"
I tried using ST_Length(the_geom), ST_Length(the_geom,true) and the results
are as follows,
*the_geom geometry(LineString,4326)*
"0102000020E6100000030000008204C58F31C551C070AC8BDB682C4540DA1B7C6132C551C0BF7D1D38672C45403333333333C551C00D4FAF94652C4540"
> *ST_Length(the_geom)*0.000141421356226931
> *ST_Length(the_geom,true) *i.e spheroid=true
> 13.8305487635736
What is the metric used for these st_length values? Also if I want to use
length as my edge cost in a graph formed out of these linestrings which
length function I should use?
Thanks,
Raghavan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140421/3e6d5119/attachment.html>
