[postgis-users] Error installing postgis 2.1.2 on postgresql 9.2.8 on solaris 10 (x86)
Tambade, Kedar ktambade at cghtech.com
Tue Apr 22 08:10:20 PDT 2014
Thank you, Phillip
Will give it a try with the patch.
Regards,
Kedar Tambade
CGH Technologies, Inc.
Phone: 571.723.4821
Email: ktambade at cghtech.com<mailto:mnash at cghtech.com>
This electronic mail message and any attached files contain information intended for the exclusive use of the individual or entity to whom it is addressed and may contain information that is propriety, privileged, confidential and/or exempt from disclosure under applicable law. If you are not the intended recipient, you are hereby notified that any viewing, copying, disclosure or distribution of this information may be subject to legal restriction or sanction. Please notify the sender, by electronic mail or telephone, of any unintended recipients and delete the original message without making any copies.
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Phillip Ross
Sent: Monday, April 21, 2014 9:05 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Error installing postgis 2.1.2 on postgresql 9.2.8 on solaris 10 (x86)
Hi Kedar...
I had a similar issue with Solaris 11.  I think the config scripts need some work to properly detect the isfinite situation with Solaris environments.  I've not had the time to work through the config scripts, but I'll attach the patch that I use to get it to build on solaris 11.  This might also work on solaris 10.
Also, I'm not sure what the implications of doing it this way are, but it seems to be stable for my environments thus far.
Hope it helps!
- Phillip
On Mon, Apr 21, 2014 at 4:39 PM, Tambade, Kedar <ktambade at cghtech.com<mailto:ktambade at cghtech.com>> wrote:
Thank you Strk for the quick response...  Following are the answers to your question
Does your libm have "isfinite" ?
No, " nm -D /usr/lib/libm.so | grep -i isfinite" did not return any result.
what's available function/macro to check for finiteness ?
did not understand what should I check, can you please let me know what exactly should I check.
Note that ./configure script should be checking for isfinite, defining or not a HAVE_ISFINITE macro in postgis/postgis_config.h What does it say ?
Postgis/postgis_config.h file does not contain HAVE_ISFINITE.
Thanks & Regards,
Kedar Tambade
-----Original Message-----
From: postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org> [mailto:postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org>] On Behalf Of Sandro Santilli
Sent: Friday, April 18, 2014 10:53 AM
On Thu, Apr 17, 2014 at 07:12:13PM +0000, Tambade, Kedar wrote:
> Hello all,
> While installating the postgis 2.1.2 on solaris 10 (5.10 Generic_147441-05 i86pc i386 i86pc), I am getting the following error while doing gmake can someone please help :
> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -I../rt_core -I../../liblwgeom -I/opt/postgres/gis928/include -I/opt/postgres/gis928/include -I/opt/postgres/gis928/include raster2pgsql.o -o .libs/raster2pgsql  ../rt_core/librtcore.a -L/opt/postgres/gis928/lib ../../liblwgeom/.libs/liblwgeom.so -L/usr/sfw/lib /opt/postgres/gis928/lib/libproj.so /opt/postgres/gis928/lib/libjson.so /opt/postgres/gis928/lib/libgdal.so -L/usr/lib -L/usr/local/lib -L/usr/openwin/lib -L/usr/local/ssl/lib -L/usr/X11R6/lib -L/usr/local/BerkeleyDB.4.7/lib -L/usr/local/mysql/lib -lpq -lrt -ldl -lxml2 -lz -lpthread -lsocket -lnsl /opt/postgres/gis928/lib/libgeos_c.so /opt/postgres/gis928/lib/libgeos.so /usr/sfw/lib/libstdc++.so -lgcc_s /usr/local/lib/libiconv.so -lm -R/usr/local/lib -R/opt/postgres/gis928/lib -R/usr/sfw/lib -R/usr/lib
> Undefined                       first referenced
> symbol                             in file
> isfinite                            ../../liblwgeom/.libs/liblwgeom.so
> ld: fatal: symbol referencing errors. No output written to
> .libs/raster2pgsql
> collect2: ld returned 1 exit status
> gmake[2]: *** [raster2pgsql] Error 1
> gmake[2]: Leaving directory `/opt/postgres/repository/postgresql_9.2.8/postgis-2.1.2/raster/loader'
> following is the gcc version:
> $ gcc --version
> gcc (GCC) 3.4.3 (csl-sol210-3_4-branch+sol_rpath) Copyright (C) 2004
> Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.  There
> is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Or what's available function/macro to check for finiteness ?
Then there's code around the codebase using that macro to do different thing. Take a look. Patch is welcome once you figure out.
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140422/a6d1c5d0/attachment.html>
