[postgis-users] PG 2.0 to add table with heterogeneous geometry in QGIS
Alexandre Neto
senhor.neto at gmail.com
Fri Aug 1 04:52:10 PDT 2014
Hello sylvia,
If you are using QGIS to add polygons that should not be a problem.
On the other hand, if you are inserting rows using INSERT, then you should
use St_multi() function around your the_geom column:
st_multi(the_geom)
This will transform your polygon into a single part multipolygon.
Hope it helps,
Alexandre Neto
2014-08-01 12:03 GMT+01:00 Preuß, Sylvia <Sylvia.Preuss at obk.de>:
> Hello Alexandre,
> thanks for your hint, but I can‘ t put Polygons into a Multipolygon -
> table. When I try to insert the records into the table I get the message:
> FEHLER: Geometry type (Polygon) does not match column type (MultiPolygon)
> ********** Fehler **********
> SQL Status:22023
> PostGIS version:
> 2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> Postgres version:
> PostgreSQL 9.2.8, compiled by Visual C++ build 1600, 64-bit
> QGIS 2.4.0
> Sylvia
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Alexandre Neto
> *Sent:* Thursday, July 31, 2014 7:58 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] PG 2.0 to add table with heterogeneous
> geometry in QGIS
> you can put polygons inside a multipolygon geometry. I would not even call
> it heterogeneous.
> You just need to use:
> the_geom geometry (multipolygon,25823).
> Hope it helps,
> Alexandre Neto
> Em 31/07/2014 12:46, "Preuß, Sylvia" <Sylvia.Preuss at obk.de> escreveu:
> Hi,
> I tried with and without checking this option. I get an attribut-table but
> no geometry. It’s just like csv.
> Sylvia
> *>From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Åsmund Tokheim
> *>Sent:* Thursday, July 31, 2014 12:25 PM
> *>To:* PostGIS Users Discussion
> *>Subject:* Re: [postgis-users] PG 2.0 to add table with heterogeneous
> geometry in QGIS
> >Hi
> >When you create/edit a postgis-connection in qgis, there should be an
> checkbox named something like "Don't resolve type of unrestricted >columns".
> Your table will not be listed if this option is checked.
> >Åsmund
> >2014-07-31 11:29 GMT+02:00 Preuß, Sylvia <Sylvia.Preuss at obk.de>:
> >Hello list,
> >I have heterogeneous geometry (Polygon and MultiPolygon ) in one single
> table.
> >CREATE TABLE myschema.mytable
> >( gid serial NOT NULL,
> > the_geom geometry(geometry,25832),
> >CONSTRAINT pkey_mytable PRIMARY KEY (gid)
> >Unfortunately I can’t add this as a PostGIS –Layer in QGIS. The geometry
> is not found.
> >Same behaviour with
> >CREATE TABLE myschema. mytable
> > the_geom geometry,
> >CONSTRAINT pkey_ mytable PRIMARY KEY (gid)
> >I can’t do it like this:
> > the_geom geometry(Polygon OR MultiPolygon,25832),
> >PostGIS version:
> >Postgres version:
> >QGIS 2.4.0
> >Sylvia
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> * Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der
> dienstlichen Kommunikation. Senden Sie deshalb keine E-Mails privaten
> Inhalts an E-Mail-Adressen des Oberbergischen Kreises.*
> Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail
> gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff auf
> Ihre Nachricht hat. Für Berufsgeheimnisträger und besondere Funktionsträger
> gelten abweichende Regelungen.
> Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail
> ohne Authentifizierung und Verschlüsselung unsicher ist, da für
> unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und
> Manipulation besteht.
> Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht
> übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
> Obwohl alle angemessenen Vorkehrungen getroffen wurden, um
> sicherzustellen, dass Anlagen dieser E-Mail virusgeprüft sind, wird
> empfohlen, anhängende Dateien vor dem Öffnen durch Ihr eigenes
> Virus-Programm zu prüfen, da keinerlei Haftung für Schäden übernommen wird,
> die infolge etwaiger Software-Viren entstehen könnten.
> Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person
> bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen
> Vertretung sein sollten, beachten Sie bitte, dass jede Form der
> Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des
> Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum gebeten,
> sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140801/809bfff1/attachment.html>
