[postgis-users] FW: json/json.h: No such file or directory
Paragon Corporation
lr at pcorp.us
Sat Aug 16 09:32:37 PDT 2014
It's related to json version. Which version are you building with?
I suspect you are running a newer json. This should be fixed in 2.1.4 (2.1
trunk)
If you are building from source anyway, you might want to use our 2.1.4dev
or cut in the fix from
http://trac.osgeo.org/postgis/ticket/2723
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Gery .
Sent: Saturday, August 16, 2014 8:50 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] FW: json/json.h: No such file or directory
Hello,
I just received this after 'make' in version 2.1.3:
libtool: compile: gcc -g -O2 -DDLL_EXPORT -DPIC -Wall -Wmissing-prototypes
-I/usr/local/include -c lwin_geojson.c -DDLL_EXPORT -DPIC -o
.libs/lwin_geojson.o
lwin_geojson.c:20:23: fatal error: json/json.h: No such file or directory
#include <json/json.h> ^ compilation terminated.
Makefile:156: recipe for target 'lwin_geojson.lo' failed
make[1]: *** [lwin_geojson.lo] Error 1
make[1]: Leaving directory '/opt/postgis/postgis-2.1.3/liblwgeom'
GNUmakefile:14: recipe for target 'all' failed
make: *** [all] Error 1
I read that this is a problem related to Geos 3.4.2. My configuration is:
-------------- Compiler Info ------------- C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
SQL preprocessor: /usr/bin/cpp -w -traditional-cpp -P
-------------- Dependencies -------------- GEOS config:
/usr/local/bin/geos-config GEOS version: 3.4.2 GDAL config:
/usr/local/bin/gdal-config GDAL version: 1.11.0 PostgreSQL config:
/usr/bin/pg_config PostgreSQL version: PostgreSQL 9.3.5
PROJ4 version: 46
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.1
JSON-C support: yes
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions --------------- PostGIS Raster: enabled PostGIS
Topology: enabled SFCGAL support: disabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets: /usr/share/sgml/docbook/xsl-stylesheets
dblatex: /usr/bin/dblatex
convert: /usr/bin/convert
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
How can I circumvent this json/json.h problem and finish the installation of
postgis?
Gery
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
