[postgis-users] FW: json/json.h: No such file or directory
Gery .
gamejihou at hotmail.com
Sat Aug 16 11:18:18 PDT 2014
Hi Regina,
I tried with postgis-2.2.0dev, it seems that the json problem is gone, but 'make' didn't find '-lpostgres'. In my system, postgres is in /usr/sbin, and I put that in LD_LIBRARY_PATH of my .bashrc. Below is the message:
Gery at gery /opt/postgis/postgis-2.2.0dev
$ make
/usr/bin/perl utils/svn_repo_revision.pl
Can't fetch local revision (neither .svn nor .git found)
Not updating existing rev file at 12889
for s in liblwgeom libpgcommon postgis regress raster topology loader utils extensions; do \
echo "---- Making all in ${s}"; \
make -C ${s} all || exit 1; \
done;
---- Making all in liblwgeom
make[1]: Entering directory '/opt/postgis/postgis-2.2.0dev/liblwgeom'
make[1]: Nothing to be done for 'all'.
make[1]: Leaving directory '/opt/postgis/postgis-2.2.0dev/liblwgeom'
---- Making all in libpgcommon
make[1]: Entering directory '/opt/postgis/postgis-2.2.0dev/libpgcommon'
make[1]: Leaving directory '/opt/postgis/postgis-2.2.0dev/libpgcommon'
---- Making all in postgis
make[1]: Entering directory '/opt/postgis/postgis-2.2.0dev/postgis'
gcc -ggdb -O2 -pipe -Wimplicit-function-declaration -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -shared -o postgis-2.2.dll -Wl,--out-implib=libpostgis-2.2.a postgis_module.o lwgeom_accum.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o lwgeom_geos.o lwgeom_backend_api.o lwgeom_geos_prepared.o lwgeom_geos_clean.o lwgeom_geos_relatematch.o lwgeom_export.o lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geohash.o lwgeom_in_geojson.o lwgeom_in_encoded_polyline.o lwgeom_triggers.o lwgeom_dump.o lwgeom_dumppoints.o lwgeom_functions_lrs.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o lwgeom_transform.o gserialized_typmod.o gserialized_gist_2d.o gserialized_gist_nd.o gserialized_estimate.o geography_inout.o geography_btree.o geography_measurement.o geography_measurement_trees.o geometry_inout.o -L/usr/lib -Wl,--allow-multiple-definition -Wl,--enable-auto-import -L/usr/local/lib -Wl,--as-needed ../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a -L/usr/local/lib -lgeos_c -lproj -ljson-c -L/usr/lib -lxml2 -lz -liconv -lm -L/usr/lib -lpostgres -lpgport -lpgcommon -lintl -lssl -lcrypto -lz -lreadline -lcrypt -lldap
/usr/lib/gcc/i686-pc-cygwin/4.8.3/../../../../i686-pc-cygwin/bin/ld: cannot find -lpostgres
collect2: error: ld returned 1 exit status
/usr/lib/postgresql/pgxs/src/makefiles/../../src/Makefile.shlib:377: recipe for target 'postgis-2.2.dll' failed
make[1]: *** [postgis-2.2.dll] Error 1
make[1]: Leaving directory '/opt/postgis/postgis-2.2.0dev/postgis'
GNUmakefile:14: recipe for target 'all' failed
make: *** [all] Error 1
Any thoughts?
Gery
> From: gamejihou at hotmail.com
> To: postgis-users at lists.osgeo.org
> Date: Sat, 16 Aug 2014 17:10:32 +0000
> Subject: Re: [postgis-users] FW: json/json.h: No such file or directory
> Hello Regina,
> Thanks for your reply, I have these ones installed in cygwin (latest version 32-bit):
> Gery at gery /opt/postgis/postgis-2.1.3
> $ cygcheck -c | grep json
> json-c-debuginfo 0.11-2 OK
> libjson-c-common 0.11-2 OK
> libjson-c-devel 0.11-2 OK
> libjson-c2 0.11-2 OK
> libjson-devel 0.11-2 OK
> libjson0 0.9-1 OK
> ruby-json 1.8.0-1 OK
> Surprisingly, neither geos nor gdal has given error messages. I read some posts about that things were not smooth in cygwin with postgis as far as I remember, but here this has been the only complain. I have installed both libjson-c2 (version 0.11-2) and libjson0 (version 0.9-1), would that be the problem?
> I'll follow your suggestion and try postgis 2.1.4dev, and send a message if nothing improves.
> Gery
> Sent from Windows Mail
>> From: lr at pcorp.us
>> Date: Sat, 16 Aug 2014 12:32:37 -0400
>> It's related to json version. Which version are you building with?
>> I suspect you are running a newer json. This should be fixed in 2.1.4 (2.1
>> trunk)
>> If you are building from source anyway, you might want to use our 2.1.4dev
>> or cut in the fix from
>> http://trac.osgeo.org/postgis/ticket/2723
>> Hope that helps,
>> Regina
>> http://www.postgis.us
>> http://postgis.net
>> -----Original Message-----
>> From: postgis-users-bounces at lists.osgeo.org
>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Gery .
>> Sent: Saturday, August 16, 2014 8:50 AM
>> Subject: [postgis-users] FW: json/json.h: No such file or directory
>> Hello,
>> I just received this after 'make' in version 2.1.3:
>> libtool: compile: gcc -g -O2 -DDLL_EXPORT -DPIC -Wall -Wmissing-prototypes
>> -I/usr/local/include -c lwin_geojson.c -DDLL_EXPORT -DPIC -o
>> .libs/lwin_geojson.o
>> lwin_geojson.c:20:23: fatal error: json/json.h: No such file or directory
>> &include <json/json.h> ^ compilation terminated.
>> Makefile:156: recipe for target 'lwin_geojson.lo' failed
>> make[1]: *** [lwin_geojson.lo] Error 1
>> make[1]: Leaving directory '/opt/postgis/postgis-2.1.3/liblwgeom'
>> I read that this is a problem related to Geos 3.4.2. My configuration is:
>> -------------- Compiler Info ------------- C compiler: gcc -g -O2
>> C++ compiler: g++ -g -O2
>> SQL preprocessor: /usr/bin/cpp -w -traditional-cpp -P
>> -------------- Dependencies -------------- GEOS config:
>> /usr/local/bin/geos-config GEOS version: 3.4.2 GDAL config:
>> /usr/local/bin/gdal-config GDAL version: 1.11.0 PostgreSQL config:
>> /usr/bin/pg_config PostgreSQL version: PostgreSQL 9.3.5
>> PROJ4 version: 46
>> Libxml2 config: /usr/bin/xml2-config
>> Libxml2 version: 2.9.1
>> JSON-C support: yes
>> PostGIS debug level: 0
>> Perl: /usr/bin/perl
>> --------------- Extensions --------------- PostGIS Raster: enabled PostGIS
>> Topology: enabled SFCGAL support: disabled
>> -------- Documentation Generation --------
>> xsltproc: /usr/bin/xsltproc
>> xsl style sheets: /usr/share/sgml/docbook/xsl-stylesheets
>> dblatex: /usr/bin/dblatex
>> convert: /usr/bin/convert
>> mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>> How can I circumvent this json/json.h problem and finish the installation of
>> postgis?
>> Gery
>> postgis-users mailing list
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
