[postgis-users] pointcloud extentions
Mohammed Kabeer
mkabeer at tamimicg.com
Wed Aug 20 07:47:46 PDT 2014
Thank you sir
I copied those files and working
How to create pointcloud table and How to store .las files in in my postgis
pointclolud table
Thanks once again for your help
Kabeer
-----Original Message-----
Sent: Wednesday, August 20, 2014 4:50 PM
To: postgis-users at lists.osgeo.org
Cc: Mohammed Kabeer
Subject: Re: [postgis-users] pointcloud extentions
Have a look at https://www.google.com/search?q=pointcloud+postgis+windows
Am Mittwoch 20 August 2014, 16:36:51 schrieb Mohammed Kabeer:
> Dear sir,
> Would you please guide me how can I install that pointcloud package in
> my postgis on windows
> Thanks once again
> Kabeer
> From: Mohammed Kabeer [mailto:mkabeer at tamimicg.com]
> Sent: Wednesday, August 20, 2014 2:07 PM
> To: 'PostGIS Users Discussion'
> Cc: mkabeer at tamimicg.com
> Subject: RE: [postgis-users] pointcloud extentions
> It will be easier, though, to install a PostGIS version on a Linux
> box, then tell OpenGeoSuite to use this installation
> How can I do this process
> Thanks
> Kabeer
> Sent: Wednesday, August 20, 2014 1:50 PM
> Dear Sir,
> Right now I have windows environment existing
> You mean I need to move to linux environment or how
> Thanks
> Kabeer
> From: postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Nicolas
> Ribot
> Sent: Wednesday, August 20, 2014 1:27 PM
> To: PostGIS Users Discussion
> I guess you have to install Cygwin or another Linux env on Windows,
> then install all necessary packages and compile PointCloud.
> box, then tell OpenGeoSuite to use this installation.
> Nicolas
> On 20 August 2014 12:17, Mohammed Kabeer <mkabeer at tamimicg.com> wrote:
> Thank you very much
> How to install in windows environment
> // Create file as pointcloud.control and copy following code in it
> # pointcloud extension
> comment = 'data type for lidar point clouds'
> default_version = '1.0'
> module_pathname = '$libdir/pointcloud'
> relocatable = true
> superuser = true
> #requires = 'postgis'
> Would you please guide me how to install in windows
> Thanks
> Kabeer
> Ribot
> Sent: Wednesday, August 20, 2014 1:09 PM
> Hi,
> This extension is not part of standard postgis installation (afaik).
> You have to install it manually: https://github.com/pramsey/pointcloud
> Nicolas
> On 20 August 2014 11:37, Mohammed Kabeer <mkabeer at tamimicg.com> wrote:
> Dear Sir,
> I installed postgis with opengeosuit4. 1 (OpenGeoSuite-latest.exe) and
> created database and working fine
> I run CREATE EXTENSION postgis: // working fine
> But when I run CREATE EXTENSION pointcloud; // it gives me ERROR:
> could not open extension control file "C:/Program Files
> (x86)/Boundless/OpenGeo/bin/../pgsql/share/extension/pointcloud.control":
> No such file or directory
> SQL state: 58P01
> How to fix this problem
> Thanks
> Kabeer
> Mohammed Kabeer Ahmed | Spatial Technologies| Tamimi Consulting Group|
> Tel +966 1217 0152 | Mobile +966 545548353 <tel:%2B966%20545548353> |
> Skype: mkabeer2000 Riyadh, Saudi Arabia
> specialistCard
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
