[postgis-users] Elevation profiles from rasters
Rasmus Aveskogh rasmus at defero.se
Fri Aug 22 13:09:34 PDT 2014
Hi!
How hard/feasible would it be to implement elevation profile/drape line functionality in PostGIS? Since PostGIS already depends on GDAL I assume making use of the GDAL API would make this quite easy, such as in the Zoo-Project service:
http://www.zoo-project.org/trac/browser/trunk/zoo-project/zoo-services/gdal/profile/service.c
Providing functionality that could eventually be used for applications like: http://www.zoo-project.org/site/ZooWebSite/Demo/GdalProfile (using the code above)
I’m currently using an ad-hoc PostGIS-function to pull out elevation profiles from my rasters, but it’s quite slow and CPU intensive and as such does not make a good fit as a backend service for a web application like the above.
-ra
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140822/03a1dc96/attachment.html>
