[postgis-users] Creating trajectory/lines from millions of points[PostGIS]
Oliver Burgfeld oliver.burgfeld at gmail.com
Mon Dec 1 23:59:30 PST 2014
Hi and thanks, that's exactly what I was looking for.
But nevertheless it seems not to work as it's supposed to, I think.
If I just run the first query to detect when the status changes, I get a
really strange result.
I have at least the same amount of rows as in my original table.
But the status does not change at every point of course, so the result has
to be lower. As I have only very basic knowledge of SQL, I really don't
know how to handle this strange behaviour.
Or did I miss a thing here?
Am Montag, 1. Dezember 2014 10:50:09 UTC+1 schrieb toni hernández:
> Hi,
> Maybe this is already solved but anyway....
> As the "taxi_is_occupied" field  is boolean (or binary), if you group by
> this field you will get only two multilinestrings for each vehicle. One
> multilinestring when "taxi_is_occupied" is true, and one multilinestring
> when is false.
> If you want to get as many geometries as clients a taxi has done,  then
> you can use the window functions "LAG". With this function you can detect
> when the taxi changes from free to occupied and viceversa
> This sentence detects when taxi changes status:
> select geom, time, status, case when (status <> lag(status,1) over(order
> by time)) then 1 else 0 end as canvi from table
> From there you can count the number of times the "taxi_is_occupied" has
> changed.
> select geom, time, status, sum(canvi) over (order by time) as track_num
> from
> ) as foo
> And finally , you can use the previous SELECT statement to create all
> tracks for all taxis
> select vehicleid, st_makeline(geom), track_num, status
> from
> select vehicleid,geom, time, status, sum(canvi) over (order by time) as
> track_num from
> select vehicleid, geom, time, status, case when (status <> lag(status,1)
> over(order by time)) then 1 else 0 end as canvi from table
> ) as foo
> ) as fooo
> group by track_num, status, vehicleid
> order by track_num
> On 25/11/2014 19:16, Roxanne Reid-Bennett wrote:
> On 11/25/2014 11:48 AM, Oliver Burgfeld wrote:
> I also tried that and it works but it does not give me those two columns
> in my new table. There are only id and status inside.
>  From the quer below change
> SELECT id, status, (ST_Dump(mylines)).geom
> to
> SELECT id, status, (ST_Dump(mylines)).geom, time_start, time_end
> Something to keep an eye out for... Depending upon your version of PostGIS
> and the underlying libraries, because we were working with an older version
> of the underlying libraries, I don't know if this is still a potential
> issue.  We ran into issues with "stacked" points (2 GPS points with the
> same coordinates), and GPS drift causing issues with the linestrings being
> pretty goofy (jagged points in the linestring that were clearly NOT what
> the vehicle did).    We wrote cleanup scripts to take care of those
> issues (that are still in place).  I've not taken time to revisit the
> library routines to see if they now handle those conditions cleanly.
> Roxanne
> Am Dienstag, 25. November 2014 17:39:21 UTC+1 schrieb Brent Wood:
>  as in my previous reply, I figured that would be useful...
>  WITH multis AS (
>                 SELECT id, status,* min(timestamp) as time_start,
> max(timestamp) as time_end, *ST_MakeLine( point_geom ORDER BY timestamp) AS
> mylines
>                 FROM your_table
> GROUP BY id, status
> FROM multisBrent Wood
>  *From:* Oliver Burgfeld <oliver.... at gmail.com>
> *To:* postgi... at googlegroups.com
> *Cc:* pcr... at pcreso.com; postgi... at lists.osgeo.org;
> postgi... at lists.osgeo.org; remi... at gmail.com
> *Sent:* Wednesday, November 26, 2014 5:10 AM
> *Subject:* Re: [postgis-users] Creating trajectory/lines from millions of
> points[PostGIS]
>  Thank you and all the others who were answering :)
> I tried that and it seems that its working. Nevertheless I only tried it
> with a small part of my data (round about 1 million rows out of ~500
> million) but if it's working now, it should also work with the whole
> dataset.
> Is there a way to also include the time_field into the result? I created a
> new table with this statement given but there are only two columns
> (vehicleid and status) included.
> I know thats logical because I only included those two into my select
> clause but it would be great to not only order by time but also have a time
> column in my table.
> For example:
> vehicleid | status | time_start | time_end
> I hope its understandable and not to mixed up...
> Thanks!
> Am Dienstag, 25. November 2014 16:06:33 UTC+1 schrieb Rémi Cura:
>   Hey, a small correction :
>  ST_MakeLine is already an aggregate, and you may want to enforce the
> order inside the aggregate (see at the end).
>  Another interesting point is the possiblity to pu somehting in the M
> value of each point of the line, for instance the time.
>  This comes very handy when you want to extrat parts of the lines.
>  So for instance for the first proposition :
> WITH multis AS (
>                 SELECT id, status,* ST_MakeLine( point_**geom ORDER BY
> time_field) *AS mylines
>                 FROM your_table
> GROUP BY id, status
> FROM multis
>  Cheers,
> Rémi-c
> 2014-11-25 9:53 GMT+01:00 Brent Wood <pcr... at pcreso.com>:
>   or automatically get the start & end times for each trackline in the
> record like this:
>  WITH multis AS (
>                 SELECT id, min(time_field) AS time_start, max(time_field)
> as time_end, status, ST_MakeLine(array_agg(point_ geom )) AS mylines
>                  FROM your_table
> GROUP BY id, status
> ORDER BY time_field
> FROM multis;
>  Cheers,
>    Brent Wood
>  *From:* Hugues François <hugues.... at irstea.fr>
> *To:* PostGIS Users Discussion <postgi... at lists.osgeo.org >
> *Sent:* Tuesday, November 25, 2014 8:13 PM
> points[PostGIS]
>   Hello,
> In your case I would have try to make multilines for each taxi and each
> status (i.e. two multi by taxi) and then dump them into  simple
> linestrings. All in a query that may look like this assuming you have a
> taxi id field:
> WITH multis AS (
>                 SELECT id, status, ST_MakeLine(array_agg(point_ geom )) AS
> mylines
>                 FROM your_table
> GROUP BY id, status
> ORDER BY time_field
> FROM multis
> You may want to add a time reference to your lines. To do this, you can
> add an extraction from your timestamp field (e.g. day or month) and add it
> into the WITH and to the group by clause.
> Hugues.
> *De :* postgis-us... at lists. osgeo.org [mailto:postgis-us...@
> lists.osgeo.org] *De la part de* Oliver Burgfeld
> *Envoyé :* mardi 25 novembre 2014 07:09
> *À :* postgi... at lists.osgeo.org
> *Objet :* [postgis-users] Creating trajectory/lines from millions of
> points[PostGIS]
>   Hi,
> I have millions of points in a PostGIS database containing taxi gps
> tracks. Now I want to create lines from these points by vehicleid and
> ordered by timestamp. But, and that's my problem right now, at first I want
> to include every column of my point table into the "line table" and I also
> need to intersect those lines at specific points.
> I have one column representing the "taxi_is_occupied" status with 0 or 1.
> What I want now is to create lines which are divided every time this
> status changes. In the end I need lines which show the path of every taxi
> over time, divided every time the status of the car changes so that I can
> query all lines where the taxi is occupied, for example.
> What do I have to use therefore? I know that there is the ST_MakeLines
> tool existing in PostGIS, but as I am a new PostGIS
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141201/c47bb8c7/attachment-0001.html>
