[postgis-users] PostgreSQL 9.3.4/PostGIS 2.1.1 function
Burgess, Freddie FBurgess at Radiantblue.com
Fri Dec 5 14:46:59 PST 2014
Will this function work?
Does this look right
-- Name: polygon_radiant_to_latLong(geometry); Type: FUNCTION; Schema: public; Owner: -
CREATE OR REPLACE FUNCTION polygon_radian_to_latLong(geom geometry)
returns geometry[] as
select array_agg(latlong) from (
select path,st_astext(geom) as "radians",st_setsrid(st_scale(st_astext(geom)::geometry,180.0/pi(),180.0/pi()),4326) as "latlong"
  from ST_DumpPoints($1::geometry) as p) as foo;
$$ LANGUAGE 'sql';
ownsdb=# select * from (
ownsdb(# select path,st_astext(geom) as "radians",st_astext(st_setsrid(st_scale(st_astext(geom)::geometry,180.0/pi(),180.0/pi()),4326)) as "latlong"
ownsdb(#   from ST_DumpPoints('POLYGON((326454.7 5455793.7,326621.3 5455813.7,326455.4 5455796.6,326454.7 5455793.7))'::geometry) as p) as foo;
 path  |          radians          |                 latlong
 {1,1} | POINT(326454.7 5455793.7) | POINT(18704476.5122094 312593952.904064)
 {1,2} | POINT(326621.3 5455813.7) | POINT(18714021.9890763 312595098.819654)
 {1,3} | POINT(326455.4 5455796.6) | POINT(18704516.6192551 312594119.061824)
 {1,4} | POINT(326454.7 5455793.7) | POINT(18704476.5122094 312593952.904064)
(4 rows)
select st_astext(unnest(polygon_radiant_to_latLong('POLYGON((326454.7 5455793.7,326621.3 5455813.7,326455.4 5455796.6,326454.7 5455793.7))'::geometry)));
thanks
Sent: Friday, December 05, 2014 5:40 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] PostgreSQL 9.3.4/PostGIS 2.1.1 function
From: postgis-users-bounces at lists.osgeo.org [postgis-users-bounces at lists.osgeo.org] on behalf of Stephen Mather [stephen at smathermather.com]
Sent: Friday, December 05, 2014 4:34 PM
Subject: Re: [postgis-users] PostgreSQL 9.3.4/PostGIS 2.1.1 function
Sorry typos and such, try this again:
select st_astext(st_setsrid(st_scale(geom,180.0/pi(),180.0/pi()),4326)) FROM table_containing_polygons;
Best,
Steve
On Fri, Dec 5, 2014 at 4:30 PM, Stephen Mather <stephen at smathermather.com<mailto:stephen at smathermather.com>> wrote:
Hi Freddie,
select st_astext(st_setsrid(st_scale('POINT(1
1)'::geometry,180.0/pi(),180.0/pi()),4326)) FROM table_containing_polygon;
Best,
Steve
On Fri, Dec 5, 2014 at 3:33 PM, Burgess, Freddie <FBurgess at radiantblue.com<mailto:FBurgess at radiantblue.com>> wrote:
How would I do this on a polygon?
Thanks
________________________________________
From: postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org> [postgis-users-bounces at lists.osgeo.org<mailto:postgis-users-bounces at lists.osgeo.org>] on behalf of Paul Ramsey [pramsey at cleverelephant.ca<mailto:pramsey at cleverelephant.ca>]
Sent: Thursday, December 04, 2014 6:51 PM
I would think that scaling by 180/pi should do the trick in general?
select st_astext(st_setsrid(st_scale('POINT(1 1)'::geometry,180.0/pi(),180.0/pi()),4326));
P
On Thu, Dec 4, 2014 at 3:24 PM, Burgess, Freddie
> Given a polygon geometry with no SRID, the vertices actually in radians, but
> since the SRID is zero, it looks like Cartesian coordinates, I want the lat
> long in degrees and not rads.
> Does anyone provide of a function/custom that will return lat/long in
> degrees given the conditions described?
> thanks
> postgis-users mailing list
> postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141205/c578c5ad/attachment.html>
