[postgis-users] postgis.gdal_enabled_drivers not working out for me
Rhys A.D. Stewart rhys.stewart at gmail.com
Sat Dec 6 16:08:13 PST 2014
Thanks!!!
Was reading the dev documentation. Problem solved.
Rhys
Peace & Love|Live Long & Prosper
On Sat, Dec 6, 2014 at 12:09 PM, Bborie Park <dustymugs at gmail.com> wrote:
> The GUC postgis.gdal_enabled_drivers is not available in 2.1. Instead you
> need to specify the equivalent environmental variable for PostgreSQL.
> POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL
> I don't know which OS you're using but at least on Ubuntu, you would add the
> above to
> /etc/postgresql/9.3/CLUSTER_NAME/environment
> where CLUSTER_NAME is the name you gave for the PostgreSQL data cluster.
> On Sat, Dec 6, 2014 at 3:42 AM, Rhys A.D. Stewart <rhys.stewart at gmail.com>
> wrote:
>> Greetings all,
>> Tried using st_aspng and got a lovely error saying
>>    ERROR:  rt_raster_to_gdal: Could not load the output GDAL driver
>> Did some research and found out about postgis.gdal_enabled_drivers. I
>> set it to 'ENABLE_ALL'  in postgres.conf and no luck. Tried as a
>> session variable but still no luck.
>> I can't figure out what I am missing.
>> Here is my version info:
>> POSTGIS="2.1.4 r12966" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
>> 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.9.2"
>> LIBJSON="UNKNOWN" RASTER
>> PostgreSQL 9.3.5 on x86_64-pc-linux-gnu, compiled by
>> x86_64-pc-linux-gnu-gcc (Funtoo 4.8.2-r3) 4.8.2, 64-bit
>> Rhys
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
