[postgis-users] Help CONSTRAINTS and others questions
Hugues François hugues.francois at irstea.fr
Sun Dec 7 01:39:25 PST 2014
Hello,
I'm not sure to understand well your problems but it seems you have sql questions rather than postgis ones... For the first one, I don't really understand what you are looking for but I think what you want to add is constraint called foreign key (you will find useful information in the postgres documentation). For your second questions, you may achieve that using a trigger function but you have to be aware that it will not work if you have a not null or a primary key constraint (except if you have a serial type, a sequence, or any other rule in your trigger function to fill this column automatically)
Hugues.
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Alessio Degioannini
Envoyé : samedi 6 décembre 2014 13:32
À : postgis-users
Objet : [postgis-users] Help CONSTRAINTS and others questions
I'm a postgis/postgres newbie and I I would like to get some help on the topics that I'm going to describe.
I have imported into the database the shapefile "survey" of points (trees). The spatial table "survey" contains five columns:
- "Gid" (created during import and primary key, integer)
- "Id"
- "Code"
- "Old number"
- "Geom" (it also created during import).
The database includes several tables ("Species", "Defects", "Disease" and others) related to the main table "VTA".
Now I would like to know why, unlike what happened to the other tables, I can not connect with "ADD CONSTRAINT" column "code" (integer, not null, unique) of the table "VTA" to the corresponding column "code" (also integer, not null) the spatial table "survey".
Another question: when I'm editing a field (for example "species name" in the column "species" of table "VTA", related to the table "Species", would that "species name" could be completed on the basis of the records in the table "Species". How can I do this?
Thanks in advance.
Alessio
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141207/8085e004/attachment.html>
