[postgis-users] Dynamic parameters to ST_MapAlgebra
Guillaume Drolet
droletguillaume at gmail.com
Wed Dec 10 06:41:19 PST 2014
I'm trying to find the best way to dynamically apply scaling factors to a
raster. I've tried different approaches using ST_MapAlgebra, both callback
and expression versions. The fastest method so far is this one but it
doesn't allow for dynamic parameters:
SELECT ST_MapAlgebra(rast, 1, '32BF', '([rast] * 0.01) + 0') AS rast,
FROM evi;
Compared to using the following function, the query above is ten times
faster:
CREATE OR REPLACE FUNCTION public.scale_sds_plv8(value double
precision[][][],
pos integer[][], VARIADIC userargs text[])
RETURNS double precision AS
var g = Number(userargs[0]);
var o = Number(userargs[1]);
return (value * g + o);
$$ LANGUAGE plv8 IMMUTABLE;
WITH scaling_params AS (
SELECT gain, off_set
FROM meta
WHERE product = 'MCD12Q2' AND sds = 'EVI'
SELECT ST_MapAlgebra(rast, 1, 'scale_sds_plv8(double
precision[], integer[], text[])'::regprocedure, '32BF', 'FIRST',
NULL::raster, 0, 0,
VARIADIC ARRAY[gain, off_set]::text[]) AS rast
FROM evi, scaling_params
I want to take advantage of the speed of the first method above but be able
to pass parameters dynamically instead of hard-coding them in the query. To
this aim I tried this approach:
CREATE OR REPLACE FUNCTION scale_sds_plpgsql(rast raster, gain float8,
offs float8 DEFAULT 0)
RETURNS raster AS $$
DECLARE
sql text;
BEGIN
sql := 'SELECT ST_MapAlgebra(' || rast ||
', 1, ''32BF'', ''([rast] * ' ||
gain || ') + ' || offs || ''')';
EXECUTE sql;
END;
$$ LANGUAGE plpgsql IMMUTABLE;
SELECT scale_sds_plpgsql(rast, 0.01, 0.0)
FROM evi;
Running this last query, I get a synthax error which I don't understand:
ERREUR: erreur de syntaxe sur ou près de «
F400000000000407FC05E10B2668C203F41A0BD86AA1F7C2....
CONTEXT: fonction PL/pgsql scale_rast(raster,double precision,double
precision), ligne 12 à instruction EXECUTE
********** Error **********
I'm sure there are experienced folks on this list who will have some clues
to solve this or who will come up with a better approach.
Thanks a lot for your time.
G
View this message in context: http://postgis.17.x6.nabble.com/Dynamic-parameters-to-ST-MapAlgebra-tp5007468.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
