[postgis-users] Dynamic parameters to ST_MapAlgebra
Paragon Corporation
lr at pcorp.us
Wed Dec 10 12:30:32 PST 2014
Guillaume,
If the expression approach is faster, is there some reason you aren't just
doing
WITH scaling_params AS (
SELECT gain::text As gain, off_set::text as off_set
FROM meta
WHERE product = 'MCD12Q2' AND sds = 'EVI'
SELECT ST_MapAlgebra(rast, 1, '32BF', '([rast] * ' || gain || ') + ' ||
off_set ) AS rast
FROM evi, scaling_params;
Or is that too hard-coded for you?
The downside I see of using plpgsql is it has to copy each raster again into
the your new function so it uses at least twice the amount of memory of the
above.
Now regarding the one that Hugues gave you, you have to run it differently
from how you were calling your others, otherwise it would take forever since
for every raster row you have it would apply map algebra to all the rows in
your table. So how did you call his?
If you wanted to use the syntax you have I would rewrite your plpgsql as
follows (and not use dynamic sql) - you don't need dynamic sql to do this
just call ST_MapAlgebra directly.
CREATE OR REPLACE FUNCTION scale_sds_plpgsql(rast raster, gain float8,
offs float8 DEFAULT 0)
RETURNS raster AS $$
BEGIN
RETURN ST_MapAlgebra(rast, 1, '32BF', '([rast] * ' ||
quote_literal(gain) || ') + ' || quote_literal(offs) );
EXECUTE sql;
END;
$$ LANGUAGE plpgsql IMMUTABLE;
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Guillaume Drolet
Sent: Wednesday, December 10, 2014 2:56 PM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Dynamic parameters to ST_MapAlgebra
Hugues: thank a lot for your fix.
The function now runs without error... but it's been running for almost an
hour now :(
Compared to the 30-ish seconds it takes using the hard-coded query, and the
some 120 seconds using the PLV8 version, I cannot think of using the PLPGSQL
version in its current formulation.
Does anyone else has a possibly faster suggestion, more in the ballpark of
the two other methods?
Thanks,
G
View this message in context:
http://postgis.17.x6.nabble.com/Dynamic-parameters-to-ST-MapAlgebra-tp500746
8p5007470.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
