[postgis-users] Why won’t my SELECT query use the INDEX?
Rémi Cura
remi.cura at gmail.com
Tue Dec 16 08:43:44 PST 2014
Hey,
no index can come from 2 problems :
- your querry can't use the index
- your querry could use the index but the planner thinks it's faster to
do sequential scan.
You can discriminate between the 2 avoiding explicitly sequential scan :
`SET enable_seqscan TO FALSE`
(don't forget to turn it back one afterward)
if you are still not using index, your querry can't use it at all, thus
there is a problem of definition.
Cheers,
Rémi-C
2014-12-16 17:23 GMT+01:00 Andy Colson <andy at squeakycode.net>:
> On 12/16/2014 9:18 AM, Casper Børgesen (CABO) wrote:
>> This seems like one of the most asked questions in the PostgreSQL world,
>> but I guess I haven’t understood all the answers yet:
>> Why won’t my SELECT query use the INDEX I have created for it?
>> I have a table with about 18mio rows.
>> My SELECT statement looks like this:
>> SELECT "id",encode(ST_AsEWKB("geom"),'base64') as "geometry"
>> FROM my_table
>> WHERE geom &&
>> ST_GeomFromText('POLYGON ((892267.1937422 6148208.34251139,
>> 892500.497129949 6148208.34251139, 892500.497129949 6148009.40012468,
>> 892267.1937422 6148009.40012468, 892267.1937422 6148208.34251139))',
>> ST_SRID("geom"))
>> The EXPLAIN ANALYZE of the above statement returned this:
>> "Seq Scan on my_table (cost=0.00..4329124.83 rows=1731 width=1700)
>> (actual time=194785.745..1553525.244 rows=138 loops=1)"
>> " Filter: (geom && st_geomfromtext('POLYGON ((892267.1937422
>> 6148208.34251139, 892500.497129949 6148208.34251139, 892500.497129949
>> 6148009.40012468, 892267.1937422 6148009.40012468, 892267.1937422
>> 6148208.34251139))'::text, st_srid(geom)))"
>> " Rows Removed by Filter: 17311187"
>> "Total runtime: 1553525.352 ms"
>> The POLYGON described above is located at the outer edge of the 17mio
>> geometries and the extent is pretty small.
>> I have executed a VACUUM ANALYZE to clean up the statistics, which
>> didn’t seem to improve the results.
>> My INDEX has been created like this:
>> CREATE INDEX my_table_geom_idx
>> ON my_table
>> USING gist
>> (geom);
>> Upon reading up on this issue I have changed the following in my
>> postgresql.conf:
>> random_page_cost = 2.0
>> shared_buffers = 512MB
>> work_mem = 8MB
>> maintenance_work_mem = 256MB
>> effective_cache_size = 8GB
>> The HARDWARE is a Windows 2012R2 with 12GB ram and SAS HDDs. PostgreSQL
>> 9.3 x64 and PostGIS 2.1.1.
>> Can any ask me the right questions so I can solve my INDEX problem?
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> I doubt changing postgresql.conf options will have any affect.
> Its the st_srid(geom) call that's a problem.
> Remove it, or specify the integer value. The function call messes it up.
> This should work:
> explain analyze
> FROM my_table
> WHERE geom &&
> 892267.1937422 6148009.40012468, 892267.1937422 6148208.34251139))')
> -Andy
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141216/0de4b936/attachment.html>
