[postgis-users] Problem with shp2pgsql and the -W character encoding option
Rémi Cura remi.cura at gmail.com
Fri Feb 7 08:29:10 PST 2014
Maybe you could try to expressely set it to corresponding
iso-8859-1 = LATIN1
(instead of latin1)
or maybe IBM850.
If you are on windows, you can just donwload previous version to try with
older binaries.
Cheers,
Rémi-C
2014-02-07 Michael Fricker <michael.fricker at altusgroup.com>:
>         Hello. I’ve run into a problem with shp2pgsql, at the command
> prompt, where the –W option to change the default character encoding of
> UTF-8 to, for example LATIN1, is not working. If I’m correct, the –W
> character encoding option should allow you to switch from the default UTF-8
> to any other character encode that is required. In my case it is LATIN1. I
> used the following line below to store the .sql file.
> shp2pgsql.exe -d -s 2956:3401 -I -W "LATIN1"
> "C:\0\Canada_Land_Survey_Data\test\Deliverables\CLSR_Land_Parcel.shp"
> scratch.ab_clsr_land_parcel >
> C:\0\Canada_Land_Survey_Data\Data_Dump\Land_Parcel_Error.sql
> A portion of the result is shown below.
> SET CLIENT_ENCODING TO UTF8;
> SET STANDARD_CONFORMING_STRINGS TO ON;
> SELECT DropGeometryColumn('scratch','ab_clsr_land_parcel','geom');
> DROP TABLE "scratch"."ab_clsr_land_parcel";
> BEGIN;
> CREATE TABLE "scratch"."ab_clsr_land_parcel" (gid serial,
> "pin" float8,
> "designator" varchar(254),
> "remain_ind" varchar(254),
> "planno" varchar(30),
> "admin_code" varchar(20),
> "pcl_type" varchar(254),
> "lcselectio" varchar(100),
> "remarks" varchar(254),
> "pcl_state" varchar(254),
> "reg_pin" varchar(254));
> ALTER TABLE "scratch"."ab_clsr_land_parcel" ADD PRIMARY KEY (gid);
> SELECT AddGeometryColumn(
> 'scratch','ab_clsr_land_parcel','geom','3401','MULTIPOLYGON',2);
> I would have expected the first line to have read SET CLIENT_ENCODING TOLATIN1  instead of
> SET CLIENT_ENCODING TO UTF8.
> Initially I was attempting to upload a shapefile to a database at work
> using this command;
> scratch.ab_clsr_land_parcel | psql.exe -h "localhost" -p "5432" -U
> "postgres" -d "major_testing_db"
> Instead of being uploaded, the resulting error occurred:
> ERROR:  unterminated quoted string at or near “’”
> LINE 1:   …o”,”remarks”,”pcl_state”,”reg_pin”,geom> VALUES <’1115077’,’
> Reading through the .sql file, I tracked down the problem to be a
> character not supported by UTF-8 in the following line (the small arrow
> highlighted in red);
> INSERT INTO "scratch"."ab_clsr_land_parcel" ("pin","designator","remain_ind","planno","admin_code","pcl_type","lcselectio","remarks","pcl_state","reg_pin",geom)
> VALUES ('1115077','EJERE K’ELNI KUE INDIAN RESERVE 196I','No','84988 CLSR
> AB','09888','Inside Canada Lands',NULL,NULL,'ACTIVE',NULL,ST_Transform('
> 01060000208C0B00…….
> When I used the shp2pgsql-gui and selected LATIN1 for the character
> encoding, the shapefile was uploaded to the database without incident. Any
> help and/or explanation would be appreciated. The version of both shp2pgsql
> and shp2pgsql-gui that I have used is 2.1.0. Thanks to anyone for their
> help.
> *Michael Fricker*
> GIS Technician
> Altus Geomatics
> Limited Partnership
> T: 403.234.7599 ext 2395
> F: 403.261.4712
> 840 7th Avenue SW, Suite 900
> Calgary, Alberta  T2P 3G2  Canada
> *This message, and the documents attached hereto, are intended only for
> the addressee and may contain privileged or confidential information. Any
> unauthorized disclosure is strictly prohibited. If you have received this
> message in error, please notify us immediately so that we may correct our
> internal records. Please then delete the original message. Thank you.*
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140207/615eb14b/attachment.html>
