[postgis-users] hard upgrade of database fails because of tsvector syntax error
Scott Pezanowski
scottpez at hotmail.com
Mon Feb 10 04:27:24 PST 2014
Richard and Sandro,
Thank you for your replies and suggestions.
Richard, I think your suggestion is a good one and may have worked. Unfortunately, because of various reasons, the original DB does not exist anymore.
I may possibly have to let this one go; At least for now. All of the PostGIS functionality we use is when data is written to the DB. At this point, we are no longer writing to the database, but only reading what has previously been processed. Therefore, I think we will be ok with what we have through pg_restore. If I have any further updates or resolutions, I will let you know.
Thank you both again for the suggestions.Scott
********************************************* Scott Pezanowski
email: scottpez at hotmail.com
> Date: Fri, 31 Jan 2014 09:36:26 +0100
> From: strk at keybit.net
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] hard upgrade of database fails because of tsvector syntax error
> On Thu, Jan 30, 2014 at 01:05:45PM -0500, Scott Pezanowski wrote:
> > Sandro,
> > Thank you for your advice and I apologize for the lengthy delay in my reply. Based on your advice, I seem to have narrowed the problem to one record the restore script hits and its tsvector value (perhaps there are other records that may fail after this, but the restore fails to get past this one). Below is the error I am getting when using postgis_restore.pl.
> > Reading list of functions to ignore... Writing manifest of things to read from dump file... Writing ASCII to stdout...ERROR: syntax error in tsvector: "'2012':5 'call':8 'elect':17 'gagnam':12 'hurrican':14 'koni':7 'mayb':10 'olymp':11 'presidenti':16 'rt':1 'sandi':15 'stop':6 'style':13 'summari':3 'wt"CONTEXT: COPY twitter_datatable_2012_12, line 46295160, column textsearchable_index_col_with_stop: "'2012':5 'call':8 'elect':17 'gagnam':12 'hurrican':14 'koni':7 'mayb':10 'olymp':11 'presidenti':16..."
> > The actual complete tsvector text is shown below.
> > "'2012':5 'call':8 'elect':17 'gagnam':12 'hurrican':14 'koni':7 'mayb':10 'olymp':11 'presidenti':16 'rt':1 'sandi':15 'stop':6 'style':13 'summari':3 'wtffact':2"
> > Therefore, there is more text in the tsvector field, which seems to be being truncated. I do not see anything out of the ordinary with any characters near where the truncation occurs, that would cause this - Unless it is perhaps actually failing somewhere other than at the 'wt part. Do you think there may be a need for some sort of escape of certain characters like the apostrophe? Or perhaps a length imposed on the text?
> > I am not quite sure what the problem with the data could be. If I simply insert the full actual value into the tsvector column, it inserts fine. So I think it seems like the text being truncated for some reason causes the "syntax error".
> > Based upon this, can you see what the problem may be or do you have any other suggestions on things I can look at to try to diagnose the problem?
> First thing I'd do is try to re-create the problem with a new small dump.
> It sounds like postgis_restore.pl is truncating a line, but dunno why
> it would do that (maybe some env variable affecting perl run ?).
> Once you have the small dump you could compare pg_restore output with
> postgis_restore one to see is this is the case (truncation performed
> by postgis_restore..).
> --strk;
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140210/dc0e143a/attachment.html>
