[postgis-users] Upgrade postgres 9.0 -> 9.3 mantainingpostgis1.5?
Frank Broniewski brfr at metrico.lu
Thu Feb 20 08:00:52 PST 2014
This is really helpful, thank you very much! I'll write down what I'll
be doing and post my recipe here on the list for further reference for
others,
Frank
Am 2014-02-19 21:56, schrieb Paragon Corporation:
> Frank, You don't need to use postgis_restore.pl if you are
> restoring just tables with geometries.  Doesn't hurt to use it
> though.
> What postgis_restore.pl does is exclude restoring postgis packaged
> functions, types, operators etc. and also renames deprecated table
> constraints.  If you do a simple restore over a new postgis, you'll
> get ambiguous function name conflicts.
> What I did forget to mention in last post is that if you are coming
> from PostGIS 1.5, you'll probably want to install
> legacy.sql
> File.
> So steps
> Create extension postgis; Install legacy.sql
> Restore your data - if you restore the whole backup that contains
> postgis old functions -- use postgis_restore.pl (otherwise you can
> get away with just using pg_restore).
> Hope that helps, Regina http://www.postgis.us http://postgis.net
> -----Original Message----- From:
> postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Frank
> Broniewski Sent: Wednesday, February 19, 2014 3:01 AM To:
> postgis-users at lists.osgeo.org Subject: Re: [postgis-users] Upgrade
> Hi Regina,
> I've had a similar question a few days ago and unfortunately no
> reply so far. When you write
>> reload your PostGIS tables
> do you mean to use the postgis_restore.pl script to do that? My
> package / software system will only let me upgrade both Postgresql
> (from 9.0 to 9.3) and Postgis (from 1.5 to 2.1) at once and not one
> after another so I am looking for a solution on how to get by
> upgrade done smoothly
> Thanks,
> Frank
> Am 2014-02-18 11:41, schrieb Paragon Corporation:
>> Giorgio,
>> For 9.2 you can install 1.5.6+ (though we frown on people using
>> 1.5 with 9.2) . 9.3+ supports only 2.1+
>> Refer to the Support Matrix for details
>> http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
>> Regarding if you can dump table with geometries, putting aside
>> tables with no reference to postgis whatsoever -- yes you can.
>> 1) In theory you could just do a pg_upgrade (you might have to
>> drop your postgis tables and uninstall postgis first) -> 9.3
>> Then install PostGIS 2.1 on your new server and reload your
>> postgis tables
>> or
>> 2) backup your postgis tables, uninstall PostGIS 1.5, install
>> PostGIS 2.1, reload your PostGIS tables --> then pg_upgrade over
>> to 9.3
>> _____
>> From: postgis-users-bounces at lists.osgeo.org
>> Sorbara, Giorgio (CIOK) Sent: Friday, February 14, 2014 5:49 AM
>> To: postgis-users at lists.osgeo.org Subject: [postgis-users]
>> Upgrade postgres 9.0 -> 9.3 mantaining postgis1.5?
>> Dear all,
>> I am about to upgrade postgres from 9.0 to 9.3 but the gis team
>> would like to maintain postgis 1.5 version.
>>> From what I have browsed around it seems that as of the 9.2
>>> version only 2.0
>> is supported.
>> Can you confirm this?
>> If that is correct I need to upgrade 1.5 -> 2.0 before upgrading
>> the server, so far so good.
>> Then comes another question. the only way to upgrade is to dump
>> and reimport databases.
>> Now it happens that we have tables with geometries which count
>> roughly 10000 records, but in the same database we have tables
>> with billions records (which I would like not to dump)
>> Is it possible for the sake of upgrading postgis, to just dump
>> tables with geometries, putting aside tables with no reference to
>> postgis whatsoever?
>> thank you,
>> g
>> _______________________________________________ postgis-users
>> mailing list postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
