[postgis-users] postgis topology strange behavior
Gonçalo Revez
goncalorevez at gmail.com
Mon Feb 24 07:06:04 PST 2014
Hi, answers below:
On Mon, Feb 24, 2014 at 1:53 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Mon, Feb 24, 2014 at 12:01:28PM +0000, Gonçalo Revez wrote:
> > Hello,
> > I'm using the postgis topology with the following example below.
> > It inserts three contiguous polygons, but the third has a strange
> behavior.
> > It seems that the polygon doesn't snap totally to the other polygon (with
> > model tolerance of 0.1), where he should split the edges and create a
> node.
> > The problem raises two edges "overlapped". (I attach an image showing the
> > topology error).
> Does ValidateTopology catches that error ?
*G: No the validation doesn't catch any error.*
> > In fact, using the jts viewer, the third polygon overlaps the first
> > polygon, but below the topology model tolerance.
> In the topology primitives tables there are no polygons, the errors
> you're after are overlapping or crossing edges, can you find them ?
*G: yes, the edges, 2 and 6, are overlapped (or seems to).*
*I attach two image with edge2 identified and edge6 identified (where they
share some part)*
*Shouldn't be create an edge between the part both edges share (and created
a node) ?*
*For example, if I override the tolerance value of the model through **the
function toTopoGeom of the insert of the polygon 3, *
*with a value around 4 meter, I get the expected. The edges are splitted.*
*But the edges doesn't distance more than 1 meter.*
> > How is it possible to solve this type of situation or what could be the
> > error in example?
> Can it be you're referring to TopoGeometry overlap ?
> Those ones are not errors, but perfectly leagal situations.
> You can find them by counting the number of TopoGeometry objects
> each topolgy face primitive contributes to.
> Faces with count > 1 are overlaps, faces with count < 1 are "gaps".
*G: I have 3 polygons, 3 topoGeometry and 3 faces (and face 0). It didn't
create gaps.*
*If i tried to insert the third polygon again, meaning, duplicate the
topogeometry table record, and then using the same faceid , i get *
*the error: geometry intersects edge 6*
*Thanks*
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140224/9cd8135e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140224/9cd8135e/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140224/9cd8135e/attachment-0001.png>
