[postgis-users] segmentize lines with order
Rémi Cura
remi.cura at gmail.com
Tue Feb 25 00:33:20 PST 2014
Hey,
I don't understand your problem.
If you have multilinestring, you need to break it to linestring with an id
per multilinestring.
If you have linestring, you just need to keep an id for each line and an id
per point (given in path).
Then you have several option to generate a ordered set of point (use the
ORDER BY and the row_number() postgres function).
If you give some detailled example maybe we could help better.
Cheers,
Rémi-C
2014-02-24 19:27 GMT+01:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
> On 2/24/2014 11:33 AM, Pedro Costa wrote:
>> Hi guys,
>> I'm trying to use lines from postgis to google maps android.
>> To do that, I'm converting the lines to points with St_DumpPoints and,
>> in gmaps, I make the lines. My problem is that I cannot create a correct
>> sequence to order the points in android and so i get wrong lines (see ss
>> atached). I'm already try to use st_dumpPoints path column and generate
>> a serial but doesn't result.
>> Anybody knows a solution to resolve that?
> You probably need to write function that re-orients you lines before you
> dump them to points. The algorithm is like this:
> 1. for the first edge, if the start point match the the start or end of
> the 2nd edge, if it does then st_reverse() the first edge.
> 2. for the rest of the edges, if the edge point of the current edge
> matches the end point of the last edge, then st_reverse() the current edge.
> You might be able to st_union all the edges into one large edge and that
> should create a new reorder edge.
> No you can dump them and the order will be correct.
> -Steve
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140225/63b9ee39/attachment.html>
