[postgis-users] segmentize lines with order
Pedro Costa pedrocostaarma at sapo.pt
Tue Feb 25 02:45:59 PST 2014
Hi Stephen,
Thanks, I was searching some function to change draw order of lines but
i cannot remembered the postgis function name.
Now I'm trying to do a stored procedure to put the lines in the same order.
Anybody knows some code example that do something like this? I have
little experience with pl/pgsql and i'm facing something difficult with
a loop...
Thanks
Em 24-02-2014 18:27, Stephen Woodbridge escreveu:
> On 2/24/2014 11:33 AM, Pedro Costa wrote:
>> Hi guys,
>> I'm trying to use lines from postgis to google maps android.
>> To do that, I'm converting the lines to points with St_DumpPoints and,
>> in gmaps, I make the lines. My problem is that I cannot create a correct
>> sequence to order the points in android and so i get wrong lines (see ss
>> atached). I'm already try to use st_dumpPoints path column and generate
>> a serial but doesn't result.
>> Anybody knows a solution to resolve that?
> You probably need to write function that re-orients you lines before
> you dump them to points. The algorithm is like this:
> 1. for the first edge, if the start point match the the start or end
> of the 2nd edge, if it does then st_reverse() the first edge.
> 2. for the rest of the edges, if the edge point of the current edge
> matches the end point of the last edge, then st_reverse() the current
> edge.
> You might be able to st_union all the edges into one large edge and
> that should create a new reorder edge.
> No you can dump them and the order will be correct.
> -Steve
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
