[postgis-users] segmentize lines with order
    Pedro Costa
    pedrocostaarma at sapo.pt
    Tue Feb 25 06:02:27 PST 2014
With next line I mean next ' line geom' .  I need to verify if endPoint
of line 1 is the same as start point of line 2. My problem is when I
have a lot of lines with 'draw order wrong'. See ss atached, i need to
reverse line 2, 3 and 4.
Do you undestand me now? Or not :-)?
My query:
SELECT     CASE
       WHEN ST_DWithin(ST_EndPoint(r1.geom),ST_EndPoint(r2.geom),1) THEN 1
       WHEN ST_DWithin(ST_EndPoint(r2.geom),ST_StartPoint(r1.geom),1) THEN 1
     ELSE 0
     END AS reverse,
     r1.seq AS r1,
     r2.seq AS r2,
     r3.seq AS r3
FROM path r1, path2 r2, path2 r3
WHERE r1.seq = r2.seq + 1 AND r2.seq = r3.seq + 1 AND r1.seq <> 0 AND
r2.seq <> 0
Em 25-02-2014 13:50, Rémi Cura escreveu:
> I still don't understand what you are trying to do,
> if you want to access the next row of a querry, you need to order the
> row .
> So what does "next line" mean? How is this information stored?
> It is possible to access other rows using windows function :
> http://www.postgresql.org/docs/9.3/static/functions-window.html
> However I'm not certain you really need it.
> Could you provide a simple test case and an explanation of what you
> are trying to do?
> (somehting like
> create table my_test;
> insert into my_test some_geometry_you_have_trouble_with;
> --describe the kind of result you want...
> --The problem is ..., I want to do ..., I tried ...
> Cheers,
> Rémi-C
> 2014-02-25 12:59 GMT+01:00 Pedro Costa <pedrocostaarma at sapo.pt
> <mailto:pedrocostaarma at sapo.pt>>:
>     I was trying CASE before but i doesn't know how to access 'next
>     line start point'.
>     Example:
>     SELECT
>         CASE
>          WHEN (ST_Intersects(ST_EndPoint(geom),(SELECT
>     ST_StartPoint(geom) FROM lines WHERE seq = seq+1))) <--- I need to
>     get next line geom
>                 THEN 1
>         ELSE 0
>         END AS reverse
>     FROM lines
>     Do you understand my problem?
>     Em 25-02-2014 11:42, Rémi Cura escreveu:
>>     You don't need a stored procedure,
>>     you can simply use pure sql with the CASE WHEN ... THEN .. WHEN
>>     .. THEN .. .. END.
>>     doc :
>>     http://www.postgresql.org/docs/9.3/static/functions-conditional.html
>>     If you still need plpgsql :
>>     http://www.postgresql.org/docs/9.3/static/plpgsql-control-structures.html#PLPGSQL-STATEMENTS-RETURNING
>>     Cheers,
>>     Rémi-C
>>     2014-02-25 12:17 GMT+01:00 Pedro Costa <pedrocostaarma at sapo.pt
>>         thanks Remi.
>>         I'm tying to make a stored procedure to use st_reverse when
>>         draw order is wrong.
>>         Now, my difficult is in writing the loop.
>>         I can't find something like that to guide me...
>>         Em 25-02-2014 11:11, Rémi Cura escreveu:
>>>         You can use
>>>         http://postgis.refractions.net/docs/ST_Reverse.html
>>>         Or simply ORDER BY DESC for your path
>>>         Cheers,
>>>         Rémi-C
>>>         2014-02-25 11:49 GMT+01:00 Pedro Costa
>>>         <pedrocostaarma at sapo.pt <mailto:pedrocostaarma at sapo.pt>>:
>>>             Hi Rémi,
>>>             Thanks for your awnser.
>>>             My problem is that the draw order isn't equal in all
>>>             lines so the path of st_dumppoints sometimes return
>>>             ascend order and another times descend. I need to make a
>>>             loop to make a reverse...
>>>             Em 25-02-2014 08:33, Rémi Cura escreveu:
>>>>             Hey,
>>>>             I don't understand your problem.
>>>>             If you have multilinestring, you need to break it to
>>>>             linestring with an id per multilinestring.
>>>>             If you have linestring, you just need to keep an id for
>>>>             each line and an id per point (given in path).
>>>>             Then you have several option to generate a ordered set
>>>>             of point (use the ORDER BY and the row_number()
>>>>             postgres function).
>>>>             If you give some detailled example maybe we could help
>>>>             better.
>>>>             Cheers,
>>>>             Rémi-C
>>>>             2014-02-24 19:27 GMT+01:00 Stephen Woodbridge
>>>>             <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>:
>>>>                 On 2/24/2014 11:33 AM, Pedro Costa wrote:
>>>>                     Hi guys,
>>>>                     I'm trying to use lines from postgis to google
>>>>                     maps android.
>>>>                     To do that, I'm converting the lines to points
>>>>                     with St_DumpPoints and,
>>>>                     in gmaps, I make the lines. My problem is that
>>>>                     I cannot create a correct
>>>>                     sequence to order the points in android and so
>>>>                     i get wrong lines (see ss
>>>>                     atached). I'm already try to use st_dumpPoints
>>>>                     path column and generate
>>>>                     a serial but doesn't result.
>>>>                     Anybody knows a solution to resolve that?
>>>>                 You probably need to write function that re-orients
>>>>                 you lines before you dump them to points. The
>>>>                 algorithm is like this:
>>>>                 1. for the first edge, if the start point match the
>>>>                 the start or end of the 2nd edge, if it does then
>>>>                 st_reverse() the first edge.
>>>>                 2. for the rest of the edges, if the edge point of
>>>>                 the current edge matches the end point of the last
>>>>                 edge, then st_reverse() the current edge.
>>>>                 You might be able to st_union all the edges into
>>>>                 one large edge and that should create a new reorder
>>>>                 edge.
>>>>                 No you can dump them and the order will be correct.
>>>>                 -Steve
>>>>                 _______________________________________________
>>>>                 postgis-users mailing list
>>>>                 postgis-users at lists.osgeo.org
>>>>                 <mailto:postgis-users at lists.osgeo.org>
>>>>                 http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>             postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140225/4a20dc33/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140225/4a20dc33/attachment.png>
