[postgis-users] PostgreSQL geometric data types vs GEOMETRY data type
Baris Ergun
barisergun75 at gmail.com
Thu Jan 2 12:49:33 PST 2014
Hi Peter;
Can u share ur CREATE Table sqls for both tables u are testing against to
be more specific.
On 2 January 2014 21:10, Peter Len <peteralen at earthlink.net> wrote:
> I am using PostgreSQL 9.1 with PostGIS. I am still doing a lot of
> documentation reading but have the following question.... PostgreSQL comes
> with some default geometric datatypes like POINT and POLYGON. I created a
> couple of tables with these types and added some data. After installing
> PostGIS, I came to find an example of creating a table with a GEOMETRY
> column. It then went on to show the use of the PostGIS ST_GeomFromText
> method. That worked fine on my test table that I created with the
> GEOMETRY(Point) data type but did not work on the table with just the POINT
> data type. So..... to use the PostGIS methods/functions, do the spatial
> columns need to be defined as GEOMETRY / GEOGRAPHY rather than the
> PostgreSQL data types of POINT, POLYGON, etc?
> Thanks - Peter
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Barış
www.linkedin.com/in/barisergun
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140102/a332c286/attachment.html>
